  • DIY Bench Power Supply #12 – Heat Transfer Follow-up
    April 24, 2015 Posted in: Video
    A follow-up to the "Heat Transfer between Transistor and Heatsink / Thermal Resistance" video
  • This is a follow-up to the “Heat Transfer between Transistor and Heatsink / Thermal Resistance” video. I demonstrate and use the Extech GX900 multimeter which helped me remotely monitor the status of the tests via Bluetooth.
    http://www.extech.com/instruments/pro…
    Buy the GX900 here: http://astore.amazon.com/m0711-20/det…
    I was asked to test a mica TO-3 washer and heatsink compound. I was also asked to test active cooling with a fan both drawing air away from the power transistor and blowing air directly on it.
    Thanks to Chris of http://www.analysir.com/blog/ for the Bourns 10K multi-turn pots: http://www.bourns.com/ProductLine.asp…
    http://www.alliedelec.com/search/resu…
    http://www.digikey.com/product-search…
    • Extech GX900 TRUE RMS Graphical Multimeter with Bluetooth
  • If you're unable to see the products related to this post it's very likely that you have your browser's ad-blocker enabled. Please support content creation on MJLorton.com by turning off your ad-blocker. Thanks, Martin
