DIY Bench Power Supply #2 – Initial Circuit draft and parts
Posted in: VideoI draft the circuit diagram and parts list of my college power supply as this will form the basis of the design
In this series we are going to go through the design and build process of a variable bench power supply.
In this video I draft the circuit diagram and parts list of my college power supply as this will form the basis of the design. Improvements to the design will be an output switch, initial current setting without dummy load, both coarse and fine voltage / current adjustment.
Future videos in this series will cover: “soft” output switch design, power supply design, enclosure / case design, printed circuit board (PCB) design and manufacture, analog and digital display options for current and voltage, breadboard to PCB design with DesignSpark by RS Components: http://www.designspark.com/
