• Electronic DC Load #3 – What is the function of the dummy load resistor?
    An explanation of how the circuit works for the dummy load and some tweaks to increase the constant current...and is
  • Link to Kibi’s “Dave Jones’ dummy load with added features” :
    http://mjlorton.com/forum/index.php?t…
    Dave Jones / EEVblog video:
    http://www.youtube.com/watch?v=8xX2SV…
    WHAT IS AN OP-AMP?:
    http://talkingelectronics.com/project…
    My components:
    * Infineon MOSFET N-channel 200V 13.5A TO-220 – BUZ31L H
    * Vishay 534 Series Pot with 6.34mm shaft, 50K
    * 2 x 10 k Ohm resistors
    * Arcol HS50 Al house wirewound high power resistor,1R (1 ohm) 50W – HS50 1R J
    * National Semiconductor Quad op amp,LM324N 1MHz DIP14
    * How does an N Channel logic level MOSFET work – gate voltage, variable resistance, heat dissipation.
    * How does a LM324N Op Amp work – voltage follower, comparator, rail to rail, head room, feedback loop.
    * What is the heat / power dissipation from a variable resistor?
