  • Electronic DC Load #5 – Final circuit before build
    September 24, 2012 Posted in: Video
    A look at the final circuit before the build.
  • Diagram and components on forum here:
    http://mjlorton.com/forum/index.php?t…
    Link to Kibi’s “Dave Jones’ dummy load with added features” :
    Dave Jones / EEVblog video:
    http://www.youtube.com/watch?v=8xX2SV…
    WHAT IS AN OP-AMP?:
    http://talkingelectronics.com/project…
    My components:
    * Infineon MOSFET N-channel 200V 13.5A TO-220 – BUZ31L H (I will be using two of these in parallel)
    * Vishay 534 Series Pot with 6.34mm shaft, 50K
    * Vishay 534 Series Pot with 6.34mm shaft, 5K
    * 1 x 10 k Ohm resistor
    * 1 x 10 turn 10K trim pot
    * Arcol HS50 Al house wirewound high power resistor,1R (1 ohm) 50W – HS50 1R J
    * National Semiconductor Quad op amp,LM324N 1MHz DIP14
    * 1uF Capacitor
    * How does an N Channel logic level MOSFET work – gate voltage, variable resistance, heat dissipation.
    * How does a LM324N Op Amp work – voltage follower, comparator, rail to rail, head room, feedback loop.
    * What is the heat / power dissipation from a variable resistor?
    I talk about Joshua’s Youtube channel: https://www.youtube.com/user/jjoster
    His electronic DC load video:
    1- http://www.youtube.com/watch?v=mkymew…
    2- http://www.youtube.com/watch?v=M26jP3…
    3- http://www.youtube.com/watch?v=jXnKK5…
    4- http://www.youtube.com/watch?v=WSQeZd…
    Kickstarter Video for my Mini USB Host Board (Arduino Compatible) :
    http://www.youtube.com/watch?v=pwg39X…
    http://www.kickstarter.com/projects/9…
