Electronic DC Load #6 – Layout and test on proto PCB / Stripboard
Posted in: VideoA quick look at the layout and operation of the circuit on a prototyping PCB
A quick look at the circuit on the stripboard PCB so that measurements can be taken to aid with completing the enclosure design.
Dave Jones / EEVblog video:
http://www.youtube.com/watch?v=8xX2SV…Veroboard Stripboard Software:
http://www.printedcircuitsboards.com/…
Fritzing here: http://www.fritzing.orgMy components:
* Infineon MOSFET N-channel 200V 13.5A TO-220 – BUZ31L H
* Vishay 534 Series Pot with 6.34mm shaft, 50K
* 2 x 10 k Ohm resistors
* Arcol HS50 Al house wirewound high power resistor,1R (1 ohm) 50W – HS50 1R J
* National Semiconductor Quad op amp,LM324N 1MHz DIP14
