I downloaded Martin's video (part 2) in 720p and watched it carefully.
The bad soldering Martin found on the 1k ohm resistor which caused the defective resistance readings is NOT a "one of".
For example (timestamps in brackets)...
1) left plastic post holding the fuse board is already cracked after being removed once (11:33)
2) lots of leftover flux (11:54)
3) small solder bits all over input jacks/board
4) solder splash above C21 (13:14)
5) U7 obviously hand soldered, too much solder, crooked (13:29)
6) Z1 has massive solder bridge to R44 and it has massive solder bridge to D6 (14:00)
7) R91 hand soldered - too much solder on top part (14:29)
8] CR2032 battery holder - too much solder on top part, bottom part looks like it was soldered with used solder (dull gray color)
9) R43 obviously hand soldered (17:25)
10) R80 (21:11) has nice solder curl on top (obviously hand soldered)
I'm sure I could have found more if there were high resolution photos or if I could have downloaded this video in 1080p.
For $600 USD MSRP, the soldering quality is very disappointing.
