Youtube Video Episodes => YouTube Video Episodes => Topic started by: metroman on March 27, 2016, 05:13:18 PM
Just joined the forum. I have a fluke 115 multimeter. I have been looking at the you tube videos on this meter. I feel that I must disagree with the display problem on the 115. I find it to be fine, the only bad display i have found is when the back light is on, at certain angles i think it is difficult to see.
Martin
I think your device is having problems. You should check it out.
I have used and evaluated the [url]Fluke 115[ https://techmaster.com.vn/dong-ho-van-nang-fluke-115-true-rms/url] as a multifunctional power meter, providing users with many applications for checking electrical equipment and electrical systems. The device is equipped with True RMS, which effectively measures many different lines in the circuit. AC / DC voltage measurement with 600.0 mV rating; measuring 600 Ohm circuit, automatic alarm <20 Ohm, switching off> 25 Ohm, breaking open circuit or short circuit of 500µS or longer; resistance measurement with a range of 40,00 Mohm / 0.01 Mohm; measuring capacitance> 1000 µF, accuracy of 5% + 20%; Measuring range frequency 50kHz / 0.01 kHz. Model 115 measures the main circuits with 600V power measurement. The appropriate voltage level measures a 3-phase power distribution system, withstands continuous overpressure that can occur on the grid or in industrial environments. The device meets all electrical safety standards CAT III 600V, IEC 61010-1, providing safety and peace of mind for users. It makes my work much more effective.
