Multimeter safety, certification, injuries, etc.. => Multimeter safety, certification, injuries, etc... => Topic started by: Polesch on February 03, 2014, 03:45:07 PM
Title: I fried my multimeter in the socket
Post by: Polesch on February 03, 2014, 03:45:07 PM
So I bought this Victor VC97 Multimeter (http://youtu.be/7H-4qLhWuu0 (http://youtu.be/7H-4qLhWuu0)), I measured the voltage of the socket with it to 230.13V (Northern Europe), and then just to test the frequency measurement on it I changed the setting and inserted the two probes in the socket - heard a scratching noise, like short fast-burning pyrotehnic fuse - and it was dead. I'm just a curious guy that know very little about electricity in general, and this was unexpected for me even after reading the manual (which is here: https://dl.dropboxusercontent.com/u/15526481/docs/601e-0097-000a.pdf (https://dl.dropboxusercontent.com/u/15526481/docs/601e-0097-000a.pdf)). Based on those specifications, did I do something wrong here?
(I know the probes and the mode was set correctly).
Title: Re: I fried my multimeter in the socket
Post by: SeanB on February 03, 2014, 11:08:09 PM
Mains peak voltage in your case is 325V, and the max input voltage is 250v for frequency. This is an absolute max, so you were 75V over this.
Post by: Polesch on February 04, 2014, 01:00:20 AM
I see, thank you.
Post by: retiredcaps on February 04, 2014, 01:39:42 AM
and it was dead.
Does it turn on with readings on the lcd?
Post by: Polesch on February 04, 2014, 04:19:25 AM
and it was dead.
No, nothing happens on any setting/mode. I'll take it apart later today (won't bother about the warranty as it's my fault), I'll see if I can find something and take a picture.
Post by: retiredcaps on February 04, 2014, 03:30:52 PM
Yes, please post some clear focus photos and I'll see if I can help you possibly fix it.  The schematic is available as I mentioned in this thread
http://mjlorton.com/forum/index.php?topic=349.0
Post by: MJLorton on February 04, 2014, 03:49:17 PM
Polesch, thanks very much for your post...even if it is your fault we can all learn from it...also...always good to see what happens inside a meter when something like this happens.
