HAM Radio > HAM Radio
My Handy project nearly finished
Paul Collins M0BSW:
I've been working on & off on this little project, as a part of my test equipment, its a set of generators, a 1 hz at 1 pps, a fast edge pulse generator at 2.64/5 kHz, and a signal generator from 1 hz to 100khz, all very useful and in the one box. next project already started, variable signal generator , sweep generator, and a ramp generator. then the wobulator gets my full attention, planned for next year concentrating on my favourite part of the hobby , servicing, fault finding & repairing. See Martin useful things to build , you have more experience than me.
Paul Collins M0BSW:
This to me what electronics is all about , you research, design build and use it, this is part of my signal generator project above, this module is the 1 Hz per/sec. very stable works well, calibration of sorts was with my DDS frequency, would have preferred using my Blackstar Meteor ,lowest measurement is 5 Hz.
Very small, and will do nicely.
Paul Collins M0BSW:
--- Quote from: SeanB on August 31, 2013, 02:38:00 PM ---Very small, and will do nicely.
--- End quote ---
Thanks Sean, I try to keep it all small these days, case metal bashing is the next thing , as you probably all ready know, you rarely find the just right enclosure, and I bought a powder coating spray equipment, including oven, so I want to have a go at making my own enclosures, steadily. I think Martin is supposed to be metal bashing for this power supply, I think it's a power supply, it's been a long time since the last part.
