Older Technology => Older Technology => Topic started by: Mr Eastwood on April 12, 2019, 07:49:42 AM
Another Ebay low cost ex-mod purchase to add to the collection; not too much to say other the unit looks good inside, no sign of any previous battery leaks. Very nice item, I look forward to playing around with it on the bench.
[edit]
Link to a similar unit https://www.vintage-radio.net/forum/showthread.php?t=126780 (https://www.vintage-radio.net/forum/showthread.php?t=126780)
Very nice looking unit.
That is mean! >:(
Somehow it would be interesting to me, what the connected DMM shows... :'(
That is mean! >:( Somehow it would be interesting to me, what the connected DMM shows... :'(
ProBang, I know that was really mean of me, it was wrong wasn't it! :) SO to try make it up to you I have posted some readings;
the dial settings were set at: 4000 on .9999, 9.999 and 99.99 mA ranges respectively matching the images (left to right) or (top to bottom)
the meters used were: idm 305 (1), idm 305 (2), idm 305 (3) and solartron 7150 (1) and solartron 7150 (2)
Hello!
Thank you for your efforts. It seems, the 505 DC current source is still pretty well in spec. :)
(Maybe a little on the low side, but that could easily caused by the resistance of the test leads and the current shunts. The tolerances of the DMMīs are added anyways.)
So I have to say: I am really very impressed from this device. :o
When was the current source built? My guess would be: Pretty much 40 years ago.
And works still fine...
I donīt expect such a long lifetime from the items, nowadays produced.
BTW: Regarding the readings from your second Solartron 7150: 0.29 mA, 3.88 mA.
Is there sadly a problem in the lower current range? ???
Greetings
"When was the current source built? My guess would be: Pretty much 40 years ago."
Quite possibly, they used the same case design I think for a good few years.
"BTW: Regarding the readings from your second Solartron 7150: 0.29 mA, 3.88 mA.
Is there sadly a problem in the lower current range? "
VERY good point! looking at the service manual there is only 1 range for current and that is 2A; so a big jump like that looked quite odd; so i left both meters on for about 5 hrs; then re-did the readings for #1 and #2; but this time both meters were NULL'd and then i switched on the FILTER.
Basically much better readings.
Happy to see the second unit works fine, too! :)
