Arduino => Arduino => Topic started by: sul@k on January 04, 2017, 12:36:28 PM
Can anyone please help me to improve the following Genie C14 Microcontroller circuit so that it counts chances/lives by acting just like a counter?
This should function as a steady hand game.
Therefore, every time the input (push to make switch) is pressed, the next LED in the sequence lights up until the 5th red LED is on.
I am almost certain that I DON'T need additional components so it can just be a wiring or coding issue.
Thank you, really needed the help.
Not sure shorting out the voltage regulator in order to reset the microcontroller is good design practice; I've not heard of the C14 before but after having looked it up it's just a PIC 16F684 with custom firmware and very simple software targeted at the educational market. I guess they have to hack the reset like that as they have appeared to have disabled the MCLR pin, so they can use it as a IO pin in their firmware.
C14 chip which is basically the PIC16F684
https://www.rapidonline.com/pdf/13-6002.pdf (https://www.rapidonline.com/pdf/13-6002.pdf)
Where is your code?
