Arduino => Arduino => Topic started by: Hants on May 14, 2013, 02:13:48 PM
I am struggling with adding another functionality - both lamps ON. Has anybody got an idea how to add this feature without destroying code that has been written by Dr_P?
/* Light turning assistant for cars (cornering lights)
Credits to user Dr_P at http://mjlorton.com forum
int fogL = 8; // 55W Relay for L fog lamp
int fogR = 7; // 55W Relay for R fog lamp
int indL = 4; // Circuit between multiswitch and indicator relay
int indR = 2; // Circuit between multiswitch and indicator relay
void setup()
pinMode(fogL, OUTPUT);
pinMode(fogR, OUTPUT);
pinMode(indL, INPUT);
pinMode(indR, INPUT);
void loop()
int i=100; // counter initialized with "done" value
if(digitalRead(indR))
i=0; //if indicators were reversed, the cycle needs to be reset to full 5s
while(digitalRead(indR) && i<100)
i++;
digitalWrite(fogR, HIGH);
digitalWrite(fogL, LOW);
delay(50);
if(digitalRead(indL)) //same as right side
i=0;
while(digitalRead(indL) && i<100)
i++;
digitalWrite(fogR, LOW);
digitalWrite(fogL, HIGH);
delay(50);
if(!digitalRead(indR) && !digitalRead(indL)) // no indicators currently on
if(i==100) //neither indicators were on OR the 5s cycle is over
else //one or both indicators were on for less than 5s
while(!digitalRead(indR) && !digitalRead(indL) && i<100) //but not any more
i++; //finish the 5s cycle in the last foglight configuration
delay(50);
Hi, is this what you mean ?
int swBoth = ?????;
void setup()
pinMode(swBoth, INPUT);
void loop()
i++;
if(!swBoth) {
else {
delay(50);
i=0;
i++;
if(!swBoth) {
else {
delay(50);
delay(50);
Sadly.. Nope.
Now both lamps are going ON for 5 seconds when I switch 'indL' or 'indR.'
'swBoth' doesn't do anything
Thanks for trying!
In addition to what you had initially, you want a push-button to light both fog lights? And I suppoze it has priority over everything else?
Sadly.. Nope.
doh! sorry i missed the digital read! hopefully now when swBoth input is switched "high" both fog lights will come on when you use the LH RH indicator; and when "low" it will work as normal; if not, I'm going to throw all my microchip pics into the bin!! ;-)
replace ...
if(!swBoth) {
with..
if( !digitalRead(swBoth) ) {
ok, the swBoth (high) as an over-ride both lights version, maybe? :-)
int swBoth = ?????;
void setup() {
void loop() {
if(digitalRead(indR)) {
while(digitalRead(indR) && i<100) {
i++;
if(! digitalRead(swBoth) ) {
else {
delay(50);
if(digitalRead(indL)) { //same as right side
i=0;
while(digitalRead(indL) && i<100) {
i++;
else {
delay(50);
if(!digitalRead(indR) && !digitalRead(indL)) { // no indicators currently on
if(i==100) { //neither indicators were on OR the 5s cycle is over
else {
else { //one or both indicators were on for less than 5s
while(!digitalRead(indR) && !digitalRead(indL) && i<100 && !digitalRead(swBoth) ) { //but not any more
delay(50);
else {
Yes :-)
Jucole - yes! it is working now!!!
I am shocked how large, long and complicated the new code is now, but if it has to be like that, than it is OK.
THANK YOU, GUYS
After few changes - final code looks like that (reversed connections on relays!):
Credits to users Dr_P and jucole at http://mjlorton.com forum
Version designed for use with relays equipped with photocoupler (JD-VCC pin)
(Pinout bank 1: [[JD-VCC, VCC]], GND; Pinout bank 2: GND, IN1, IN2, VCC)
More details about reversed connection: http://arduino.cc/forum/index.php?topic=79745.0
int swBoth = 3; // Separate switch for both fog lights
void setup() {
void loop() {
i++;
else {
delay(50);
i=0;
i++;
else {
delay(50);
else {
delay(50);
else {
If you want a shorter version this one will work too.
void turnOffFogs() {
void loop() {
if(digitalRead(swBoth)) {
mode = 3;
timer=0;
else {
mode = 1;
timer=0;
mode = 2;
timer=0;
if( (mode == 1 || mode == 2) && !digitalRead(indL) && !digitalRead(indR) && !digitalRead(swBoth) ) {
delay(50);
timer++;
if(timer==100) {
turnOffFogs();
mode = 0;
if( mode == 3 && !digitalRead(swBoth)) {
turnOffFogs();
mode = 0;
If anyone wants the same code but suitable for the microchip 16F84A @2Mhz this will get you started.
#include <pic.h>
#define fogL RA0
#define fogR RA1
#define indL RB0
#define indR RB1
#define swBoth RB2
void delay() {
int i;
for(i=0; i<800;i++) {
asm("nop");
fogL = 0;
fogR = 0;
void main() {
int mode;
int timer;
TRISA = 0;
TRISB = 255;
fogL = 0;
fogR = 0;
while(1) {
if(swBoth) {
fogL = 1;
fogR = 1;
mode = 3;
timer=0;
else {
if(indL) {
fogL = 1;
fogR = 0;
mode = 1;
timer=0;
if(indR) {
fogL = 0;
fogR = 1;
mode = 2;
timer=0;
if( (mode == 1 || mode == 2) && !indL && !indR && !swBoth ) {
delay();
timer++;
if(timer==100) {
turnOffFogs();
mode = 0;
if( mode == 3 && !swBoth) {
turnOffFogs();
mode = 0;
maybe now it's a good time to add switch debouncing (http://www.labbookpages.co.uk/electronics/debounce.html), but this time do it yourself ;)
Dr_p It not necessary as every switch is very properely grounded :-) and actually - during very long tests, I havent experienced any problems with switch bouncing
Anyway - code is interesting and is a good learning ground to me. And I am impressed with your knowledge.
I'll post a youtube link after few days to show you how it works in practice.
