General Category => General Discussion => Topic started by: Antraciet on August 11, 2013, 07:43:31 AM
Title: A good watt meter
Post by: Antraciet on August 11, 2013, 07:43:31 AM
Any ideas for a good watt/ampmeter ?
Martin tested some : http://www.youtube.com/watch?v=cCd2DDoz38g but were not that accurate, expect the last one and i don't know it can handle more than 20 amps.
Or a multimeter that can measure 20- 30 amps ? I don't want to use a clampmeter.
What i want to to do is to measure my electric equipment, like drilling machines and stuf. Because there are peeks when started and in use.
Any advice, idea is welcome.
thanks.
Title: Re: A good watt meter
Post by: iloveelectronics on August 11, 2013, 11:14:38 AM
What about these: http://www.youtube.com/watch?v=Lxv9Rozs774
Post by: Antraciet on August 11, 2013, 12:45:13 PM
But is not for 230 V ? Or is it ?
Post by: iloveelectronics on August 11, 2013, 12:51:05 PM
No, those are mainly for RC toys, etc. and only do DC up to 60V.
Post by: Antraciet on August 11, 2013, 01:18:49 PM
Yes.
I have this one : http://www.profile.eu/media/35306/Handleiding%20-%20energiemeter%20PCF%20605%20-%20EN.pdf An energy consumption meter, goes ut to 16 A. But i don't trust it  :D I have different readings when i measure something with my multimeter (only 8 A).
Normaly i have ennough with 15 A. Just to measure 1 tool.
Maybe another multimeter with datalogging ?
Post by: dr_p on August 27, 2013, 08:34:00 AM
Connor Wolf is currently working on a project for a mains power meter (similar to "kill-a-watt"). He also bought quite a few ready-made units and also received others for research purposes. There are tear-downs and reviews on his Youtube channel (http://www.youtube.com/user/Fake0Name/videos).
Post by: mariush on August 27, 2013, 02:20:04 PM
Most of these voltage/current meters can only go up to about 60v because that's the maximum voltage the IC or the linear voltage regulator powering the IC which does the math can handle.
By powering the measurement IC (microcontroller, multimeter ic) from a separate power source (coin cell battery or something), the meters could in theory support more.
However, most of these cheap meters use a simple 10 bit ADC which means they use a voltage divider to bring down the  voltage down to something the microcontroller can tolerate (let's say 5v) and then an integrated ADC converts that 0-5v into a 0-1023 interval.
So each digit in theory is 0.0048v  ... for 50v input that would mean a 0.048v step ... then you have to keep in mind that in reality, the ADC is not perfect and there's a +/- 3-5 step error, some are even worse ... so really I'd consider the minimum step about 0.1v if the meter is designed to work with up to 50-60v.
Then you have to keep in mind that the resistors used in the voltage divider will gradually warm up from the voltage regulator and the microcontroller and the current shunt near them so as they warm up they drift a bit (there's a temperature coefficient for resistors) so the accuracy will go down a bit more there... these cheap meters don't use expensive (as in 20-40 cent a piece, 0.5-1% resistors) which don't drift much as they warm up.
As for current...
These cheap meters also use kinda average current shunts with crappy temp coefficient, as they warm up from current going through them, the resistance will change a bit and the microcontroller which uses the voltage drop on the resistor to measure the current won't adjust for it, because there's no temperature sensor to keep track of that.
If price was not an issue, I'd design a current meter using a chip that uses a hall effect sensor IC like
http://www.digikey.com/product-detail/en/ACS710KLATR-12CB-T/620-1335-1-ND/2179483
http://www.digikey.com/product-detail/en/ACS711ELCTR-12AB-T/620-1370-1-ND/2470594
for up to let's say 10A of current...   and maybe something with better accuracy and higher voltage at the output like this
http://www.digikey.com/product-detail/en/ACS714ELCTR-05B-T/620-1258-1-ND/1955900
for 0-1A for better resolution/accuracy.... and/or maybe use a relay to introduce a current shunt and measure the voltage drop on it only when current is under 1A.
The hall effect sensors don't use a resistor on the current path so there would be no voltage drop, which would also be a good thing when you power a circuit from a low voltage source with limited current output like a coin cell battery or something.. basically when the voltage drop on the current shunt resistor could be enough to matter.
