Solar Power => Solar Power => Topic started by: Dawie on May 20, 2014, 02:06:00 AM
Title: Charging multiple batteries from a single PV panel
Post by: Dawie on May 20, 2014, 02:06:00 AM
Good day All
Requesting advice on the following question please:
Is it possible to charge two batteries (different capacities and physical size) from a single PV panel using a single charge controller?
Reason for the question is this.  We had a sliding gate installed with PV to charge the battery.  The installer added a second larger battery to the setup which is apparently connected in parallel with the smaller internal gate motor battery.  This parallel battery configuration is then connected to a single charge controller.
I am not convinced that this is the correct way to connect the batteries to the controller and some Googling suggested a charge controller per battery - which makes more sense.
Appreciate any feedback
Title: Re: Charging multiple batteries from a single PV panel
Post by: MJLorton on May 20, 2014, 12:58:18 PM
Hi Dawie,
You feeling is correct. Just one reason is that they will be at different states of charge as they have different capacities and a single charge controller won't control the charging process correctly across both batteries.
I would remove the smaller capacity battery and just leave the larger. If you need the additional capacity replace the smaller battery with one identical to the larger one.
Post by: Dawie on May 20, 2014, 01:50:15 PM
Cheers Martin, appreciate your feedback.
Dawie
