Arduino => Arduino => Topic started by: AMARESH on January 01, 2016, 03:41:45 AM
Hi everyone...!!! Greetings.. :)
I have a concept idea which i have ATTACHED as a picture below.. and
1. I need some clarifications regarding arduino circuitry that is the I/O board is sufficient for the components i want to use..??
2. And is it possible to convert the concept into reality..??
3. If yes... i am here to seek some help regarding the programming...
Thank You in Advance...
Amaresh.A R
Component details:
TCS3200 color sensor, TCS230 module - 2 nos
Arduino UNO ATmega328 MCB - 1 no
red, green led, piezo buzzer - each 1 no
Li-Po battery 11.1 volts rechargable battery, 2200mAh - 1 nos
Hi, I've only used my Arduino Uno to blink an LED as I much prefer the PIC MCUs; but I would guess you could get that running in a few hours.
Here is a link to a site where someone has hooked up the color sensor (perhaps the same or similar to yours?) and written some Arduino code for it. http://www.elecfreaks.com/1666.html (http://www.elecfreaks.com/1666.html)
The rest of the code should be easy enough to work out yourself.
Goodluck! :-)
Thank You for your reply sir..
Let me tell you that am a mechanical engineer.. and never used a blank IO board... am trying to find a solution in electronics for one of my problems....
am trying a microcontroller board for the first time... so im having some funny/weired/crazy doubts... pls dont feel irritated... :D
First Doubt... I need to connect two modules of color sensors which should work at a time... :)
so... should i split & connect the GND and VCC pins from arduino UNO board to respective pins of the module..!!??? ::)
Great! - it's a really nice project to do.
I can't see any problems, just read one then just read the other.
yes; also check the schematic that came with your module as from the article I linked it mentioned different versions of the module.
Thats very nice of you sir, Thank you very much for your encouraging words...!! :)
I have attached the total concept as a flowchart.. can you pls go through it and tell me whether my concept can be turned into reality..???
If there is any drawback in the logic... can you pls suggest some corrections..???
This color identification challenge means the most to me sir... Pls help me out... :)
Hi, to be honest your flowchart didn't make much sense to me;
Below is a really nice link to the color module which explains all you need to know.
http://www.geeetech.com/wiki/index.php/Arduino_TCS230_Color_Recognition_Sensor_module (http://www.geeetech.com/wiki/index.php/Arduino_TCS230_Color_Recognition_Sensor_module)
Also I've included a link to a superb free schematic drawing tool - just in case you need to draw up your schematic.
http://kicad-pcb.org/ (http://kicad-pcb.org/)
;D ;D ;D
Hmmm ok Sir.. i'll go through the link and codes.... and revert to you if i get any doubt...
thanks for the links..
