Older Technology => Older Technology => Topic started by: RobertoLG on January 03, 2016, 05:08:18 PM
Twin 16 bit DAC
Hello.
There is no connection from the casing to ground? ???
But (thin!) hot main wires are direct attached to the metal chassis from back to the front (switch)? :o
Hmm...
Greetings from Germany,
Hartmut
Supposed to be a Class II isolation, though it looks more like most electronics from the 1990's in having only a single insulated mains lead, no ground ( though there probably is a grounding lug on the back) and only single insulated wiring inside. They do fail causing shock, but that is not too common before they are replaced with new.
Very likely a standard Sony/Phillips chipset under the board, 3 IC's doing all the work, with a 2k 6116 RAM chip as deinterleaver. Looks like this is the LED/LCD display version, not enough secondaries on the transformer for the VFD versions which use 2 more secondary windings. This has 5V and + and - 12V rails.
