Author Topic: Testing a Light Bulb with a Multimeter  (Read 10829 times)
mjlainm
« on: November 23, 2016, 11:30:08 AM »
I need to test an old small 15w incandescent light (from a microwave) that seems to be burned out (but I need to make sure it is the bulb, not the circuit).
I have looked at videos on the web, but it is confusing. One said to set my (mastech) multimeter to Ohms and go from there, and one said to set it to Continuity, and go from there.
Can anyone comment?
Thanks.
Mac
USA
Re: Testing a Light Bulb with a Multimeter
« Reply #1 on: November 23, 2016, 01:38:04 PM »
Well, pretty much very likely the lamp is blown, it almost never is the microwave circuitry that blows instead. Just note, before doing anything disconnect the microwave from the mains, and put the plug in the nice little multiuse socket holes that it came in from the factory. This is mostly for your safety, there are voltages inside the microwave that are lethal, and a capacitor that can store a lethal shock for a few minutes there as well. Do not touch any of the high voltage area at all, even with the power off, unless you have had some training in the hazards involved.
 However, to test the lamp it is very simple. Disconnect the lamp ( press the 2 small tabs on the spade connectors and pull them off the terminals) so you have 2 spade connectors, almost all lamps in modern microwaves are a 15W lamp in a black bakelite base with 2 spade terminals on it, and are almost all interchangeable with the only difference being if it is a 115VAC lamp or a 230VAC lamp. To test, take your multimeter and set on 2kilohm range, and test the leads by shorting them together, which should give a reading of around 0 to 5 ohms, depending on the leads you have.  Then measure the resistance between the 2 spade connectors. Any reading that is not beyond full scale ( around 1k to 100 ohms, depends on the lamp) and which is not the same as the shorted reading means the lamp is good.  Otherwise new lamp (a whole $2) time.
While you are there, clean the inside of the lamp cavity, it gets very dirty, using a clean dry cloth to wipe most of the dust and grease off the inside. Then put in the new lamp, secure wth the single screw or bend the tab back over, and put the 2 spade connectors back on the terminals, close up the microwave case ( and put all the screws back please, and in the right holes as some do use different screws in places),  put back in position and place a cup of water inside the microwave cavity and test it. Lamp should work, and water should get hot.
mjlainm
« Reply #2 on: November 23, 2016, 01:47:05 PM »
Sean,
These are two small bulbs that unscrew very easily from below the microwave. They appear to be the "nightlight" option, and they shine down on the stove top.
These are screw type bases.  15w
I am not sure what 2 spade connectors are.
My question is:  Do I set my (mastech) multimeter to Ohms and go from there, and or to Continuity, and go from there?
See attachment.
Thanks.
PoBoySolar
« Reply #3 on: November 23, 2016, 02:01:08 PM »
Those are both basically the same thing, continuity generally has a buzzer too.   Very small lamps can have a resistance higher than the meter will detect in continuity. Any lamp should read in the 200 ohms position.  If lamp tests good, sometimes the center metal contact gets smashed down over time and doesn't make contact.  I build up a bead of solder on that and it compensates for a loss of spring tension in the socket.
mjlainm
« Reply #4 on: November 23, 2016, 02:32:35 PM »
PoBoy,
Thanks.
I figured this out (called mastech).
They pointed out that I was not pressing the Select button after going to the continuity/speaker option.
Now...it buzzes with known working bulbs, and does NOT buzz with these two E15 or whatever they are old appliance bulbs.
They said that it does not matter, in Ohm mode, if I see resistance values of 79 or whatever, since the bulb did not buzz in the continuity/speaker option.
Now to find a replacement...
Thanks again for the replies.
Mac
