Author Topic: C14 MICROCONTROLLER circuit (steady hand game)  (Read 33526 times)
sul@k
« on: January 04, 2017, 12:36:28 PM »
Can anyone please help me to improve the following  Genie C14 Microcontroller circuit so that it counts chances/lives by acting just like a counter?
This should function as a steady hand game.
Therefore, every time the input (push to make switch) is pressed, the next LED in the sequence lights up until the 5th red LED is on.
I am almost certain that I DON'T  need additional components so it can just be a wiring or coding issue.
Thank you, really needed the help.
Re: C14 MICROCONTROLLER circuit (steady hand game)
« Reply #1 on: January 05, 2017, 09:08:02 AM »
Not sure shorting out the voltage regulator in order to reset the microcontroller is good design practice;  I've not heard of the C14 before but after having looked it up it's just a PIC 16F684 with custom firmware and very simple software targeted at the educational market.  I guess they have to hack the reset like that as they have appeared to have disabled the MCLR pin, so they can use it as a IO pin in their firmware.
C14 chip which is basically the PIC16F684
https://www.rapidonline.com/pdf/13-6002.pdf
Where is your code?
