Author Topic: T4D #33 - Input Protection and Ultimate Multimeter buyers Guide  (Read 31242 times)
http://youtu.be/8-bbe0GSzls
A new shocking episode for you.
Re: T4D #33 - Input Protection and Ultimate Multimeter buyers Guide
« Reply #1 on: November 18, 2012, 10:52:45 AM »
I think you need this to test the input protection........
http://www.galleryoflights.org/mb/gallery/displayimage.php?pos=-7378
15kV at 30mA, will definitely light up your life a lot.
« Reply #2 on: November 19, 2012, 02:34:37 AM »
Classic!
Re: T4D #33 - I certainly want to do a test of the input protection on a multimeter or two...but the taser might be no contest....I might try a short through the current input with mains from the inverter....Fluke  vs Uni-T....due care and safety taken into account....
« Reply #3 on: November 19, 2012, 10:20:00 AM »
I have a spare one if you want it..... Physical address and I will send it via Berco.
Monkeh
« Reply #4 on: November 19, 2012, 02:03:00 PM »
Classic!
The fuse will pop and that'll be it.
« Reply #5 on: November 19, 2012, 03:11:31 PM »
15kV will happily arc over the fuse, and burn it's way through everything. The lamp that was there blew after a short uninteresting life ( Chinese made junk) but with this as power it gave light, and got hot enough to burn the board under it after a minute.
Monkeh
« Reply #6 on: November 19, 2012, 06:05:56 PM »
I don't think his inverter puts out 15kV.
« Reply #7 on: November 19, 2012, 11:29:30 PM »
Yes, quite right, I was thinking of the NST. Shorting the inverter output though will not be good for it, depending how the output protection is, it might be terminal for the inverter.
Monkeh
« Reply #8 on: November 20, 2012, 05:37:23 AM »
I should hope the inverter is designed to handle a short circuit until a protective device operates, otherwise it's not fit for purpose!
DaveXRQ
« Reply #9 on: November 21, 2012, 03:25:17 AM »
You put the UNI-T into the mains and it will just pop that's all  :P It's the same fuse you find in a proper UK socket and the BS1362 (not the glass rubbish that i find sometimes, not sure which idiot placed it there) blows without any fireworks or any fantastic things happening ..
