Author Topic: Inside another Block Heater  (Read 12616 times)
« on: July 28, 2013, 06:45:44 PM »
After watching Martin's video of his block heater tear-down,  I had been meaning to open the one I have up and take some pictures; so this evening after cleaning up my bench top I popped the lid and took some pictures.
I initially bought it to do some temperature tests on some small circuits and components but at the moment I've found a great use for it which is,  I line the block tray with kitchen foil, and then use it to heat modelling wax to a nice temperature which makes the clay easy to work with.
Re: Inside another Block Heater
« Reply #1 on: July 29, 2013, 12:50:05 AM »
Nice unit. High stability resistors, triac control and they used real precision opamps, so likely the sensor is a silicon linear sensor like a LM335 or some such. No real precision reference though, so they are using the supply voltage generated by the TDA1023 and it's internal reference as a source.
« Reply #2 on: July 30, 2013, 12:49:05 PM »
Very nice...thanks for the post.
