Author Topic: Solar Array Install  (Read 41469 times)
warlock
Re: Solar Array Install
« Reply #15 on: September 30, 2013, 03:37:22 PM »
The white conduit you see in the image contains the copper earthing wire which it attached to a ground spike and driven 3m into the ground.
Those cracked tiles "chipped corners" have always been there, the overlap is way bigger than the missing pieces but yes I should really replace them at some point.
Didn't do the solar water heater but that is a good point I should really do that too.
Today I produced 10.5KW and we had a bit of cloud cover, so I am well impressed. I'll give this array 6 months at which point I will probably add another 1KW
sheedl
« Reply #16 on: November 06, 2013, 02:46:32 PM »
Nice, good to see more Capetownian's going Solar :)
My install should be semi up and running this weekend, assuming it doesn't rain!
« Reply #17 on: November 11, 2013, 10:33:43 AM »
Excellent...do post some pictures and tell us about it when you are ready.
warlock
« Reply #18 on: November 13, 2013, 01:02:00 AM »
Cape Town, I'd never live there  ;),
Ballito, KZN is where I am from..... Yes please do send some pictures,
Last week I added another 2.5sqm Flat Plate Solar Collector to my existing one and introduced another geyser, it's been working really well.
warlock
« Reply #19 on: November 13, 2014, 04:52:58 AM »
So it's been just over 1 year since I installed all my Solar Equipment and Solar Geysers total Cost R75000, Electricity prices are rising again, and so far by my calculation I have been saving around R1500 or 75% of my monthly electricity bill (R18000pa).  So basically I will have my system paid off in around 4 years.. What I have to clarify though is that majority of the Saving is the Solar Geysers, they probably account for 75% of the saving. Even so it feels good to know that in 3 years effectively I'll be having free electricity.
With that said, I have gone ahead and ordered another 1KW to add to my array and I'll be installing this weekend
ShaughnK
« Reply #20 on: November 17, 2014, 12:06:24 AM »
Hi Warlock,
Your system is almost exactly what I now intend to start building myself.
Just to clarify something for me. How does your system cut off in event of Eishkom going down ?  I don't necessarily mean switch your
power off on your side, but rather how it stops feeding back into the (now offline) grid.
Shaughn
warlock
« Reply #21 on: November 17, 2014, 07:56:44 AM »
Hey ShaughnK,
Anti-islanding protection safety feature that is built into all grid-tied and hybrid grid-tie inverters. Anti-islanding protection is a way for the inverter to sense when there is a problem with the power grid, such as a power outage, and shut itself off to stop feeding power back to the grid. This is because when problems arise with the power grid it is assumed that workers will be dispatched to deal with the issue, and they want the power lines to be completely safe, and not have electricity flowing from all the nearby PV grid-tie systems.
An important product of anti-islanding protection is that a purely grid-tied PV system will only operate when the power grid is active. If there is a power outage the inverter will shut off and although the solar panels may still be generating power it will not be sent to your house.
Effectively the inverters will switch off and stop production in the event of a power failure, what this does mean though is that when Eishkom goes down for load shedding or what ever reason, your inverters will also turn off and not produce power.
There are devices out there that do AC-Coupling "very expensive" which will automatically separate you from the grid and from a battery bank simulate a mini-grid which will fool the inverters to start up again. but with that comes a load of issue, like how do you get ride of excess energy you are producing and now using. From all my research from what I have found it's not worth it. Right now I have a separate essentials loads panel where all my lights are attached to and 1 plug point for my DSL and TV, plus my 220v solar water pump, these are connected to an inverter with a 400ah battery bank, which gives we around 24 hours of usage.
Hope that helps !
ShaughnK
« Reply #22 on: November 18, 2014, 03:01:47 AM »
Hi Warlock,
Thanks for the detailed reply.  I do understand how a grid tie system works.
What I meant was I was trying to understand how your particular system is configured based on the components you have, as you were saying you were feeding power back into the grid.
I will send you a PM and perhaps we can chat when you have time.
Shaughn
P_B
« Reply #23 on: January 14, 2015, 12:08:09 PM »
Hi Warlock
What made you choose I-energy micro inverters. I am keen to build and install a PV system using micro inverters. If you want to build up a system slowly, it seems like the only way to do it. The problem is I'm not sure which system to go with. The big brand names seem to be I-energy, Renesola and Enphase. I'm sure there are others that I haven't seen yet. Does anyone have any advise or reasons why I should go with one or the other..
Regards
Paul
warlock
« Reply #24 on: January 15, 2015, 12:59:48 AM »
Hey P_B
I chose i-energy coz that's what my supplier stocked. They have since changed to Rena solar, at the end of the day as long as you make sure they have good backing, 25 years warantee, and decent efficiency then I think you'll bbe ok, right now I have had to import my last 6 inverters from Germany as the current supply of i-energy are charging about R3500ea and I landed them for about R2200. Exsolar in Capetown sell renasolar  for around R2700  and I'd get them there if I'd build again, unfortunately I have a i-management unit and need to stick to i-energy
