Author Topic: 19.7 volt panel problem  (Read 6747 times)
saulgonzalez
« on: September 23, 2013, 04:01:22 PM »
hi all, thanks for looking.
i am a newbee at solar cells, i made a 36 cell panel, 4 wats each with 0.534v per cell. at the time i finished i had 19.7 volt cell, the problem is that i have a 11 to 15 volt inverter and dont know what to do, either try to reduce the voltage or get another inverter. i did try to use the one that i have but after turning on the inverter the power starts to drop from 125 AC to almost 0 AC. at least thats what my tester tells me.
please help, should i try to reduce the voltage ? and how do i do that ???, or get a bigger inverter ?
thanks !!
Re: 19.7 volt panel problem
« Reply #1 on: September 25, 2013, 12:32:19 PM »
Hello,
I would say you need to evaluate the time and effort (and possible risk) of reconfiguring your DIY panel to a lower voltage vs the cost of a new inverter. Have you tested to see if the inverter works ok with a DC power source between 11-15 volts like a 12 volt battery?
