Author Topic: ISO-TECH Giveaway! Power Supply and Oscilloscope - December 2013  (Read 282329 times)
Link to the video: http://youtu.be/UOR37YMjIdw
Thanks to Paolo and ISO-TECH for the giveaway prizes!
ISO-TECH IPS3202  - Programmable Switching dc Power Supply, Triple Output (32V, 2A); 5V, 5A
ISO-TECH IDS6102A-U 100 Mhz Oscilloscope with Arduino Kit
See the kit here: https://plus.google.com/117751407446156045720/posts
and +1 / like and post a comment about entering with link back to this video:
1st Prize - ISO-TECH IDS6102A-U 100 Mhz Oscilloscope with Arduino Kit
1) Build an AM or FM radio circuit using only analog components (no ICs). Create a circuit diagram with DesignSpark PCB (http://www.designspark.com/) and upload it here to this forum topic / thread. Upload a photo or video of your breadboard circuit.
or
2) Build a power supply circuit. Create a circuit diagram with DesignSpark PCB (http://www.designspark.com/) and upload it here to this forum topic / thread. Upload a photo or video of your breadboard circuit.
2nd Prize - ISO-TECH IPS3202  - Programmable Switching dc Power Supply, Triple Output (32V, 2A); 5V, 5A
Go to the ISO-TECH Google + page and print the picture. Place the picture of the power supply on your work bench. Take a photo of your workbench and upload it to this forum topic / thread.
Please note, you can only enter to win one of the prizes.
« Last Edit: September 30, 2013, 06:32:25 PM by MJLorton »
Majorstrain
Re: ISO-TECH Giveaway! Power Supply and Oscilloscope - December 2013
« Reply #1 on: October 01, 2013, 01:11:31 AM »
Here is a picture of the ISO-TECH IPS3202 power supply image plugged in and ready to go.
I gives a dead steady voltage and current output as it is, but only if you want zero volts and amps. I imagine the actual power supply will have a slightly wider voltage range than my paper version.  :-)
Phil
https://plus.google.com/111112436343935382899/posts/hHzLC9T56xS
ttyz
« Reply #2 on: October 01, 2013, 03:17:30 AM »
I suppose it is not fair to enter the giveaway with my existing power supply project? So I think I will try some AM of FM circuit after finishing the supply.
I was thinking about placing a picture in my lab, but I have no lab, so it is not my case :)
Evgeny
ybi
« Reply #3 on: October 01, 2013, 04:15:45 AM »
Hello martin
thank you for this opportunity as you can see in the image i have no power supply just using some old transformers and an lm317.
YANIV
« Reply #4 on: October 01, 2013, 05:49:20 AM »
...to enter the giveaway with my existing power supply project...
I would like to know the answer too, since I have a PSU project as well, though everybody knows how I'm progressing with that. :)
Many thanks for Paolo and Martin for the offer!
« Last Edit: October 01, 2013, 05:51:10 AM by birrbert »
Monergy1
« Reply #5 on: October 01, 2013, 06:23:33 AM »
Hello Martin,
Here is a photo for the ISO-TECH power supply competition, sadly in order to get my entry in before life takes over I have not tidied the desk, but it all adds to the character! As you may see I definitely need a good quality power supply - and the prize would be really appreciated! - here's hoping!
Regards
Tony
tmm
« Reply #6 on: October 01, 2013, 07:39:05 AM »
Here's my excuse for a lab :p
You can never have too many powersupplies! Cheers.
thah4x0r
    • EEWeb profile
« Reply #7 on: October 01, 2013, 10:52:18 AM »
Hey Martin,
I will enter as well! There is just enough room above my oscilloscope in my homebuild cabinet, should fit like a charm :P!
Thanks as well to both Paolo and Martin making this give-away possible!
Boi
vdenich
« Reply #8 on: October 01, 2013, 11:51:02 AM »
Martin thank you for making this give away possible. As you can see, I am starting out. I have a Fluke volt meter and my ham gear on my workbench, but I am starting out in electronics and this would be perfect for me.
Regards,
Vincent
N2XG
« Last Edit: October 01, 2013, 04:18:21 PM by vdenich »
terr0r
« Reply #9 on: October 01, 2013, 01:37:21 PM »
here is my small bench.
105°C cap
« Reply #10 on: October 01, 2013, 02:22:21 PM »
thank you for many hours of informative and entertaining videos. Also I'm not new to electronic stuff, I learned a lot.
I placed the ISO-Tech power supply right in front of my unfinished 4 output power supply which still lacks it's most critical component: The analogue regulator part. The development of the regulator lead to massive output oscillation which heated up the output cap until it smoked and cut power. So this is how my forum name was born ;)
 I hope the real ISO-Tech brings a little more colour to the photo.
105°C cap
Paul Collins M0BSW
« Reply #11 on: October 01, 2013, 02:29:42 PM »
See how well it would look in my Radio Amateur Shack, it would be the Newest thing I'd have if I was lucky enough.
All the best luck to everyone.
Paul
Quietly Learning
noob64
« Reply #12 on: October 01, 2013, 03:00:21 PM »
Hi there,
Here is my work bench. I already built my own programmable power supply. You can see it working on my youtube channel HERE
« Last Edit: October 01, 2013, 03:04:41 PM by noob64 »
c
« Reply #13 on: October 01, 2013, 04:34:31 PM »
Mine, sorry it's a bit messy and the photo isn't that great, but hey I have a space waiting for this ISO-TECH 3202  ;)
GoatZero
« Reply #14 on: October 02, 2013, 03:11:15 AM »
My workbench runs on entusiasm, mini stuffed dogs full of static charge, smiles and an ISO-TECH IPS3202 cardboard power supply feeding my 15V DIY power supply, and yes i hacked it so, it works  ;)
