Author Topic: ISO-TECH Giveaway! Power Supply and Oscilloscope - December 2013  (Read 244785 times)
arekm
Re: ISO-TECH Giveaway! Power Supply and Oscilloscope - December 2013
« Reply #60 on: January 15, 2014, 01:27:46 PM »
Usual mess.
douart
« Reply #61 on: January 15, 2014, 04:57:11 PM »
Greetings from Oklahoma.
Please enter for Power Supply.
Approximately 6x9 foot converted bathroom area "Electronics Laboratory".
Laptop on bench for repair.
I have owned my oscilloscope for about a year and have not turned it on!
I am anxious to start many projects I have in mind.
Thank You,
douart
froese
« Reply #62 on: January 19, 2014, 12:48:02 PM »
I would love to win that ISO-TECH PSU Martin !!
 Here it is on my bench !
 I think I've done the Google+ bit correctly, its aint very easy to use, not used it before !
Thanks a lot.
« Last Edit: January 19, 2014, 01:30:04 PM by froese »
nmmbeginer
« Reply #63 on: January 20, 2014, 09:00:04 PM »
my workbench.
« Reply #64 on: January 21, 2014, 08:43:53 AM »
**** PLEASE NOTE ******
This competition has ended. The draw for the Power Supply will take place within the next day.
« Reply #65 on: January 22, 2014, 08:30:18 AM »
Thanks a lot.
Congratulations! You are the winner!!!
https://www.youtube.com/watch?v=6YV4hT6zkpQ
Please send me an email with your shipping address: martin@mjlorton.com
« Reply #66 on: January 22, 2014, 12:55:03 PM »
Well done to the winner, congrats and welcome to the forum.
froese
« Reply #67 on: January 22, 2014, 03:16:22 PM »
Thanks very much. I am over the moon !!!! :) :) :) :) :)
« Reply #68 on: January 26, 2014, 06:12:51 AM »
Dear Forum!
First of all, congratulations to froese for winning the power supply! :)
Secondly, allow me to present my attempt to build a variable power supply with reasonable performances (30 V - 4 A). My plan was to make a 4-5 minute video to present it to you live, but I'm having difficulties borrowing a good HD video camera and my Canon can film crap VGA resolution only. Anyway, I wouldn't like to miss the deadline so here we go. In this post I will present the basics only, but those of you who are interested in the details please check out dedicated topic HERE.
The main circuit of the power supply is a J-31 DIY kit from the Polish company named Jabel. I chose to go this way because manufacturing a PCB would've cost me too much both in terms of time and money. The heart of everything is an LM324N - Low Power Quad Op Amp. The transformer is a 24 Volt, roughly 100 VA toroidal one.
A key contribution to this project was made by blankfield who drew the schematic of the improved output stage. The original kit could output only 1 A of current, but mine can easily deliver the 4 A, which is the limit imposed by the transformer. The transistors: one 2N3054 and three 2N3055 on a huge heat sink. Although the heat sink is big, I couldn't keep the power supply passive and quiet; I had to add fans.
The LCD is based on a PIC micro controller (can't remember which one) and it was made by a guy who I met on a Romanian electronics forum. It can measure and display Volts, Amps and Watts. It also has a bar graph thingie which is quite cool. It is powered by a DC step down converter set to 12 V. By the way, this will power the fans too later when I wire them up.
As with the components presented above, I pushed to use quality with the rest as well. For example I swapped all the resistors with ones that have 1% tolerance, I went for bigger capacitors (4700 uF / 63 V), I decided not to use the original bridge rectifier, instead I installed a KBPC2510W and the same applies to the potentiometers which are now 10 turn versions.
One additional feature of my project is its modularity. After failing with the first kit, I decided to connect up everything as modular as possible. This way any main component can be swapped for improvement or repair. Of course, I didn't want to compromise the performance so I did my best when making the connectors. I managed to buy some cool 1-1.3 mm thick pins as well as connectors for cables and I soldered and heatshrinked them all one by one.
OK, that's about it! Having said all this I must admit the project is not finalized yet. I need to work on the case, fix the heat sink to it, install the Vernier type dials on the pots, put protection fuses, find some nicer ON/OFF buttons (main button and output live button separately) and finally I have some more ideas for cable management. But, there you have it. It works and if anybody is interested in building a power supply I can warmly recommend this one.
Many thanks to the forum members who contributed: blankfield, dr_p, Strada916, SeanB, Monkeh, runem, mariush! Only with your help was it possible to get this far and learn so much. A special thank you to our "Hero member" :) and ISO-Tech for motivation!
PS: I won't give up making the video, but in the meantime DesignSpark file and photos attached. And a request to Martin: please let me know if I qualify for the giveaway with everything I put in this post.
edit:
See the power supply in action: http://www.youtube.com/watch?v=T2hxFi8Rmno
« Last Edit: February 06, 2014, 02:55:11 PM by birrbert »
« Reply #69 on: January 30, 2014, 12:16:20 PM »
I finished my project for the Oscilloscope contest, it's done, finito. It's a battery powered portable Lab PSU and it's called LiPSU  :P
    The video I made is not my strong point, I didn't realize it's shaky and poor quality. I had no separate microphone to screen capture with audio,
instead I filmed the monitor. Also, the pocket camera I used had no way of refocusing when filming, so had to stop, refocus, continue recording.
I filled the 2GB card 3 times and exchanged 3 sets of new alkaline AA. I hope you guys like it, I've put a lot of effort into this little project.
    Overall I'm happy with the way it turned out, it's compact and quite usable. I uploaded an archive with some datasheets, eBay links, Design Spark
project, simulations and some internal pictures:  https://d.transfer.ro/LiPSU-transfer_ro-30jan-b487d6.zip
The video is here: http://www.youtube.com/watch?v=AaWT_IqzmDc
« Last Edit: January 30, 2014, 12:17:59 PM by dr_p »
TorqueRanger
« Reply #70 on: February 02, 2014, 12:46:53 PM »
I was trying for the Oscilloscope contest
I tried making a Simply FM Transmitter and was going to expand from there ...
But my 2 month daughter got really sick and spend some time in hospital ...
She is out now but take up all my time and also she is teething now....
Here is what I got
« Reply #71 on: February 04, 2014, 03:38:42 PM »
Gents,
Thanks to each and everyone of you that have entered. I'm going to go through them but you all qualify for the draw. If anything happens to be missing I will ask the judges to give you time before the draw.
Judging will take place next week (Paolo and some forum members) and I hope to announce the winner on the 14th of Feb.
Cheers and good luck,
arekm
« Reply #72 on: February 04, 2014, 03:42:59 PM »
Huh... was waiting for 0.3mm DNE wire to arrive (for ferrite based antena). Well, will try next time :)
« Reply #73 on: February 04, 2014, 04:00:29 PM »
How long before it arrives...can you post pics and circuit in DesignSpark in the mean time and it will qualify as an entry...
arekm
« Reply #74 on: February 05, 2014, 02:07:21 PM »
DNE wire arrived today!
In meanwhile screenshot of schematic editing in DesignSpark. My first DesignSpark suprise - there was no speaker component in the library and "model source". I had to create own component.
Started making ferrite based antenna (100:7 wire twists). Paper/plastic based home made coilformer. DesignSpark printed schematic on the table.
Edit, 2x update below.
Updated images and working product :)
Also no longer on breadboard.
First youtube demo. You are going to listen a bit of PR1 (Polish Radio S.A.) program on 225 kHz.
http://www.youtube.com/watch?v=fVzEfO0l7SE
Schematic. Note that device  works with 5V-9V range, too. I'm running it from PSU at 6.5V.
Device itself.
Ferrite antenna.  To make one you will need DNE 0.3 wire and 6mm-10mm ferrite core. First coil is 100 twists (not sure if
that's the correct english term). Second coil, on top of the first one is only 7 twists. Coilformer made of paper and A4 plastic
cover sheet. Later paper was removed to create a gap, so ferrite core could be moved.
Home-made coilformer.
Speaker. Note that it is "made in Poland" in ancient, 20th century by Tonsil (no longer existing company).
Soldered on tiny board.
Cut ferrite core (hardest material that I ever tried to cut in my life) since so long core is not needed. And the result.
For anyone interested: Bill of Materials generated with DesignSpark PCB - www.DesignSpark.com/pcb
Ref Name   Qty   Component     Value
BAT1       1    Battery        6.5V
U1         1    BC550CG
U2         1    BC550CG
U3         1    BC550CG
U5         1    BD14010STU
C1         1    Capacitor      1.5n
C2         1    Capacitor      10n
C5         1    Capacitor      10n
C6         1    Capacitor      10n
C3         1    Capacitor      47n
C4         1    Capacitor      560p
C7         1    Capacritor_Pol 2.2uF
D1         1    Diode          1N4148
D2         1    Diode          1N4148
L1         1    Inductor       DNE 0.3x100
L2         1    Inductor       DNE 0.3x7
R3         1    Resistor       1K
R5         1    Resistor       1.2K
R6         1    Resistor       4.7K
R4         1    Resistor       5.6K
R1         1    Resistor       10K
R2         1    Resistor       75K
R7         1    Resistor       470K
SP1        1    speaker        15 Ohm
+ 6-10mm diameter, 70mm long ferrite core
DesignSpark file with schematic also attached.
« Last Edit: February 10, 2014, 03:26:38 PM by arekm »
