Author Topic: DC Electronic Loads  (Read 7776 times)
Tony3dd
DC Electronic Loads
« on: October 18, 2013, 01:44:34 PM »
Just wondering how useful Electronic loads are, and why are they so expensive?
Re: DC Electronic Loads
« Reply #1 on: October 18, 2013, 04:48:54 PM »
I guess like any other test equipment, they are professionally designed and manufactured which probably adds cost over a DIY solution.
I've never used a commercial one though, so I don't know what they are like to use. I do have my simple DIY one, which I built for less than £15 and that is really useful, despite being quite crude.
Its definitely worth having a go at building a simple one, especially if you do anything power supply related.
« Reply #2 on: November 01, 2013, 08:08:31 PM »
Tony3dd,
  If you can afford it, I settled in on the BK-Precision 8500 300W/30A Electonic Load. So far, I love this unit. I will post a short review of it's capabilities once I master all the functions and software interface. The battery module (mode) is really detailed as to what you can test and the info you can grab from running a sequence test on a battery. Really good build quality, very accurate!
mrbearuk
« Reply #3 on: November 08, 2013, 04:41:14 AM »
To Steve or anyone who can share a schematic, I'm after a good d.i.y electronic load if anyone can share their designs.
mariush
« Reply #4 on: November 08, 2013, 11:29:06 AM »
Have a look at this one:
http://www.sleepyrobot.com/?p=136
I've made one myself, only modified it to use another mosfet. Does 3 amps at higher voltages just fine, up to 1-1.5a at lower voltages (let's say under 5v)
May look ugly but it works for me.
« Reply #5 on: November 08, 2013, 02:19:42 PM »
Mine can be seen here: http://stevecoates.net/cc_load/
That one uses a regular MOSFET and quite a high voltage (about 24V). My current version, which I haven't uploaded yet, replaces the IRF540 with a logic level MOSFET (F12N10L), and the power supply is a 9V PP3 battery.
Its pretty much the same as any basic simple circuit.
« Last Edit: November 08, 2013, 02:21:14 PM by steve30 »
