Author Topic: very simple power supply :) 1.25-18vdc 1.5A  (Read 35633 times)
taiga
« on: April 25, 2014, 10:17:51 AM »
y :) it is very simple but I built it out of all salvaged parts.
Anyways nothing special to you more advanced electrons but I'm enthused.
I'll attach a few picks and please ask question as it will help me learn!
http://i19.photobucket.com/albums/b190/zapatosverdes/Mobile%20Uploads/IMG_20140424_233930.jpg
Re: very simple power supply :) 1.25-18vdc 1.5A
« Reply #1 on: April 29, 2014, 03:30:12 AM »
What kind of IC did you use? Some photos with measurements? What about a display? :)
taiga
« Reply #2 on: April 29, 2014, 07:24:41 AM »
http://i19.photobucket.com/albums/b190/zapatosverdes/Mobile%20Uploads/IMG_20140424_234124.jpgttp://i19.photobucket.com/albums/b190/zapatosverdes/Mobile%20Uploads/IMG_20140424_234209.jpgttp://i19.photobucket.com/albums/b190/zapatosverdes/Mobile%20Uploads/IMG_20140424_234209.jpgquote author=birrbert link=topic=607.msg4190#msg4190 date=1398756612]
[/quote]
I used an lm317t. Would like to try an opamp darlington settup to get the zero volts out or any other good simple setups.
It currently has a single turn 10k (shity one that measures 8.89k :P) but I have a 10 turn in the mail :)
I also have a 4 digit 0-30vdc led meter display in the mail and a 0-10A led meter display on the way too.
Can i just put the ammeter in series on the output?
The voltmeter positive on the positive output and negative to ground?
Seems too simple...
Here are quick picture of max an min output voltage open circuit.
http://i19.photobucket.com/albums/b190/zapatosverdes/Mobile%20Uploads/IMG_20140424_234209.jpg
B.
taiga
« Reply #3 on: May 08, 2014, 11:12:00 AM »
For limiting the current with an lm317 in standard configuration, does the pot dissipate the power or the lm317 or both?
I'll have to set it up and check but thought it would be good to know before hand and burning out pots isn't fun.
« Reply #4 on: May 08, 2014, 12:22:33 PM »
The pot has to handle the full output current, but only has max 1v2 across the element. You probably will want to use a 5W wirewound unit, as to get the full current of the 317 you will pass just short of 2A through the pot and this will be in a small portion of the range, so you need a pretty high power dissipation to handle this. You need a pot that can handle 2A through the wiper, which means at least a 5W wirewound unit.
The LM317 does dissipate most of the power though, so you will need a heatsink that can handle the dissipation of the unregulated supply voltage multiplied by 2A into it, or you need to have a preregulator to dissipate most of the power instead of the regulator. With this then you typically have 5-8v across the regulator chip.
taiga
« Reply #5 on: May 08, 2014, 01:41:51 PM »
Thanks for the reply @SeanB.
That seems like a pretty ugly application... Do you think an OpAmp mosfet current regulator is a better choice?
How would I put that in the circuit? Just tack it on the input side of the voltage regulator circuit?
I'll look up some example circuits but from what I understand it would be a reverse process - so when the current reaches the set point it opens the mosfet to ground? Would the mosfet connect to the adjust pin of the lm317? Still trying to figure out how that works on paper.
I'll be able to actually see what's going on when Mr. Lorton's old scope arrives!! (Thanks again Martin!!!) which should help a ton.
From Mr. Jone's EEVBlog it sounds like it will oscillate in current limit mode, which makes sense. He uses it with another chip so I'm not sure that same application will work with the circuit I have at the moment.
So many things to learn and test.
Cheers
