Author Topic: best way to wire inverter?  (Read 17965 times)
n0ferz
« on: April 28, 2014, 05:18:16 PM »
Hey all,
I am new to solar energy and would like to know what is the best way to wire the inverter. I mean should I wire it directly to the LOAD terminals in the Charge Controller or can I just wire it directly from the battery?
I have read that you can't wire it directly to the charge controller since the LOAD inputs are for small loads but I wonder if I wire it directly from the battery when the battery charge % decreases above 50% will the charge controller shut down everything to prevent damaging the battery?
Thanks and regards from Dominican Republic!
Re: best way to wire inverter?
« Reply #1 on: April 30, 2014, 02:29:04 PM »
Can you post some details about the inverter or post a picture?
n0ferz
« Reply #2 on: April 30, 2014, 02:44:28 PM »
Sure, this is the inverter. We had it wired directly from the CC and now it is wired straight from the battery.
http://www.amazon.com/Cobra-400-Watt-12-Volt-120-Volt-Inverter/dp/B001RNOHBC/ref=sr_1_1?ie=UTF8&qid=1398883348&sr=8-1&keywords=cobra+inverter
We are powering a couple WiFi Radio Antennas and the current draw is very small. We have a 100w renogy panel with a 105amps battery!
n0ferz
« Reply #3 on: May 03, 2014, 09:00:06 AM »
What I basically want to know is if the Charger Controller will be damaged if I connect the inverter directly from the LOAD outputs?
AND
If I connect the inverter directly from the battery with clamps, will the Charge Controller shutdown in case the battery drops to a low voltage to prevent damage to the battery??
« Reply #4 on: May 20, 2014, 11:59:32 AM »
For that inverter to operate correctly it should be directly connected to the battery. The load output from the charge controller can sometimes have a noisy output which may affect the inverter. Connecting the inverter directly to the battery should eliminate that.
Assuming you have nothing else connected to the load of the CC it won't control shut down due to low voltage. That will done by the inverter if it has a low voltage shut off facility.
PadPaLow
« Reply #5 on: November 01, 2014, 06:00:25 AM »
Oh!! this is a truly amazing sight
Leesajohnson
« Reply #6 on: April 26, 2018, 08:52:39 AM »
Nice platform designed for electronic equipment discussion.
jakmaymn
« Reply #7 on: September 07, 2019, 01:49:03 AM »
Pretty sure there's no way to merge accounts, but gmail has built in mail forwarding capability, so you can at least get everything in one inbox.
