Author Topic: uk multimeter  (Read 33368 times)
woodguy60
uk multimeter
« on: July 11, 2014, 09:36:12 AM »
Hi I live in Barbados and will be going to the uk in a few week time
i am hoping to purchase a multimeter when there.
not looking for a  high cost top of the line meter
but on the other hand not crap.
can anyone suggest  brand and model number i can look for?
thanks paul
ProBang2
Re: uk multimeter
« Reply #1 on: July 11, 2014, 11:49:50 PM »
Hello.
It is nearly impossible to give an useful recommendation without any informations.
Perhaps it can be useful to answer the following questions:
  • How much money you want to spend?
  • Would you like to buy a benchtop or a handheld multimeter?
  • A new or a used one?
  • In which environment the multimeter would be used (i.e. more working outdoors or in the laboratory)?
  • How necessary is an advanced input protection (i.e. will you frequently work at the mains)?
  • You need high accurate measurements with high resolution (e.g. for making electronic design)?
  • How necessary is data-logging?
woodguy60
Re: uk multimeter
« Reply #2 on: July 12, 2014, 09:49:56 AM »
money i want to spend around 60 pounds.
benchtop or handheld
new or used ok with me.
only for indoor work
very seldom will be working on the mains
about accurate measurements. i own a cnc machine  so will be using this meter for trouble shooting
also looking to build a controller for my cnc.
also will be exprementing  with building other control circuits
Thanks Probang
paul
Re: uk multimeter
« Reply #3 on: July 14, 2014, 07:16:27 AM »
Thanks Probang
paul
What about PWM duty cycle for motor control and RPMs for rotation speeds maybe temperature might be helpful; that might push you towards a more automotive biased one maybe?
ProBang2
Re: uk multimeter
« Reply #4 on: August 05, 2014, 01:58:58 AM »
Hello Paul.
I donīt know, if it still interests. And Iīm sorry: I donīt know anything about electronic- stores in England.
Thatīs why my suggestion is more general.
IMO itīs most useful for you to get the following items together.
My suggestion:
Item
DMM Uni-T UT61E
DMM DT-830B
Component-Tester
Total
Price
41.00 GBP
  2.72 GBP
  9.69 GBP
53.41 GBP
Reasons:
Uni-T UT61E - Best bang per buck with 22000 counts resolution, TRMS, Data- logging capability and 0.1% basic accuracy.
Source:http://www.ebay.co.uk/itm/UNI-T-UT-61E-Digital-Multimeters-UT61E-/221043306594?pt=UK_Mobile_Phones_Communication_Radio_Meters&hash=item3377353062
DT-830B - Really an "El Cheapo" DMM. But it is quite handy if two measurements at the same time are needed, e.g. Volt and Ampere for determining of power-consumption.
Be aware: Using with high power circuits is dangerous!!!
Source: http://www.ebay.co.uk/itm/Mini-Portable-Ammeter-Voltmeter-Handheld-Tester-Ohmmeter-LCD-Digital-Multimeter-/400732719989?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item5d4d880b75
Component- Tester - Quite useful tool for testing and identifying stuff.
Source: http://www.ebay.co.uk/itm/ESR-Meter-Transistor-Tester-NPN-PNP-Mosfet-Thyristor-Diode-Resistor-Capactior-/171368601308?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item27e65d56dc
Yes, all this stuff comes from Hongkong. Actually you could order it in Barbados...
Further Informations:
There are four videos from the owner of this forum about the UT61E. Link to the first:
https://www.youtube.com/watch?v=Bz6CYDRl1M8
And one about the DT-830B:
https://www.youtube.com/watch?v=TL3NqkzvZ8o
And a video about the component tester, made by Steve Wagner:
https://www.youtube.com/watch?v=ztpVMtsVF68
Additional comment to the videos:
The marking with the "CE"- sign is meaningless. It seems independed tested. Itīs not! The manufacturer claims only, to meet the specs and marks it self. Safety is only independently checked with the "UL- listed"- marking (USA) or the "GS"- sign (Germany). Perhaps there are some others, I donīt know. BTW: The UT-61E is available as a german version with the "GS"-sign. It has a better input protection (bigger HRC-Fuses, spark- gap and so on) as the international version. Also it will delivered with the USB- cable instead the RS232- Connection. But itīs more expensive...
For example, a link to the german version:
http://www.pollin.de/shop/dt/MzU2OTYxOTk-/Messtechnik_Uhren/Messtechnik/Multimeter/RMS_Digital_Multimeter_UNI_T_UT61E.html
(74,95 € ~ 60 GBP + shipping and hard to get outside of Germany.)
Variation:
If you have no need for a component- tester or if you can spend a little more then 60 pounds,
then go for the Digitec DT-2843R as second DMM (instead of the DT-830B).
Reason:
It will adding functions, which the UT61E is lacking.
  • Backlight
  • Temperature
  • MaxMin Function (UT61E has Peak- Max Min)
  • AC+DC TRMS (The UT61E canīt do that)
Link to video, made by LightAges: https://www.youtube.com/watch?v=8eDWb7qkx4A
Source: http://www.ebay.co.uk/itm/Digitek-DT-2843R-AC-DC-True-RMS-Multimeter-with-Backlight-and-Temperature-/171080136251
All in all it is difficult to find a DMM that can do everything. Especially in this price range.
But I think, my suggestions have a wide range of functionality and fulfill your requirements.
Greetings,
Hartmut
