Author Topic: testing the efficiency of a solar panel  (Read 8889 times)
waspinator
« on: August 03, 2014, 07:58:41 PM »
I've got a few small solar panels I want to play around with and test their efficiencies. I want to automate the processes and was thinking of having a micro controlled electric load and logging the voltage and current generated to create IV curves. Would I want a constant current, power, or resistance load to do the tests? I've seen Dave's video about making a constant current load, but are there any similar tutorials/designs available for making constant power or resistance loads?
here are some I found:
constant current
http://www.sleepyrobot.com/wp-content/uploads/2012/01/currentload-rev2.pdf
constant power
http://www.kerrywong.com/2013/10/24/building-a-constant-currentconstant-power-electronic-load/
constant resistance
http://embedderslife.wordpress.com/2013/02/07/dummy-load-now-truly-resistive/
thanks
LeonAtchinson
Re: testing the efficiency of a solar panel
« Reply #1 on: October 26, 2014, 11:06:32 AM »
I've got a few small solar kit I want to play around with and test their efficiencies. I want to automate the processes and was thinking of having a micro controlled electric load and logging the voltage and current generated to create IV curves. Would I want a constant current, power, or resistance load to do the tests? I've seen Dave's video about making a constant current load, but are there any similar tutorials/designs available for making constant power or resistance loads?
constant current
constant power
constant resistance
thanks
Thanks..Glad you shared out the way to calculate the efficiency of these panels..I have got new solar power system so the information will surely help me
« Last Edit: October 27, 2014, 02:21:28 PM by LeonAtchinson »
