Author Topic: Only in south Africa.....  (Read 8411 times)
« on: October 20, 2014, 01:25:02 PM »
Over the last month there have been 3 times when copper thieves have broken into the local substation to steal copper wire, as this is worth nearly $5 per kilo as scrap metal. So far they have blown up a lot of stuff at the complex where I live, along with doing a signifigant amount of damage to installations around as well. The local coffee shop has had his lights, computers and coffee maker blown up each time that they have struck, and the houses along the road similarly.
By my place the photocell that controls the general lighting blew up twice, a number of garage door controllers have blown up, neighbours have had fridges, microwaves, clocks, computers, lights and modems along with TV sets blow up as well.
The thieves steal the earth wiring and the cabling for the street lighting, as that will not immediately be noticed, stripping back the cabling to expose the sheathing then stripping the copper earth wiring out of the steel armour. They then finally remove the neutral bus bar, and then disappear the same way that they came in. This leaved the balancing of the 3 phase supply up for pot luck, whichever phase has the highest load will be fine, but the other 2 phases will rise up till they balance, so you can get 60VAC on the heavily loaded phase, with 250VAC to 380VAC on the other 2 phases.
Pictures are the open manhole they use to get access to the cables in the substation.
The stolen lighting control panel. There should be cabling, breakers and contactors there on the steel frame, along with cabling to the photocell and the wiring out to the street.
The neutral connection to the transformer. They rarely steal this cable as it is an aluminium cable worth $1 per kilo. If they have time though it will go.
This is what was saving my electronics, a VDR equipped plugtop. It made the ultimate sacrifice to protect the equipment from overload. I have a few more in place as well, around a dozen so far, and I will make up some more out of the big bag of V250LA40A varistors I have. Better order more, only 16 left ;)
This poor lamp is on 24/7 lighting a stairwell, it did not survive the second time, and I only got to fix it this Sunday, after the third time. Others did survive, but blew out the lamps and the starters from the overvoltage. It should have lasted a lot more than the 15 odd years it has so far.
« Last Edit: October 20, 2014, 01:31:08 PM by SeanB »
Re: Only in south Africa.....
« Reply #1 on: October 20, 2014, 02:34:20 PM »
Is this just an isolated issue for the month or does this happen often? Either way, still very bad. I hope they catch them before real harm takes place and someone is killed!
« Reply #2 on: October 20, 2014, 02:54:01 PM »
Let us just say that there is a whole crew that only deals with cable theft, and they are busy 24/7. They took only 5 hours the first time to repair the cabling to get power back on, 8 hours the second time and the last time 7 hours. It is a problem that is massive, amounting to about 10% of the cost of running the municipality. There are issues with social needs, and the metro has had to resort to steel armoured doors, welding the access panels shut, alarm systems with private armed security guards as responders, alarm systems with pepper spray and electric fencing, razor wire and such. There is endemic theft of copper, such that you only use plastic piping outdoors, unless you bury it in concrete at least 30cm deep. At work we had to sleeve the water piping inside cast iron pipe as that is impossible to cut with a hacksaw. Taps are stolen only for the 100g of brass, so you buy cheap poor quality plastic ones that last only a year or two.
« Reply #3 on: October 21, 2014, 07:39:17 AM »
Wow, I had no idea it was that bad. It's really a shame, 100g of brass? Does not seem worth the time and effort. It sounds like it may cost more in some cases to protect the ares of interest than actually fixing or replacing.
« Reply #4 on: October 21, 2014, 07:42:26 AM »
SeanB,
  Have you considered a heavy duty UPS on your incoming mains?
« Reply #5 on: October 21, 2014, 11:58:42 AM »
Considered it, but there really is nothing other than the computer that needs it, so I just have a lot of overvoltage protection, so that if this happens it trips the mains and isolates safely. UPS has an external battery, so it will do an hour of operation, plenty of time to shut down and think dark thoughts.
