Author Topic: Gradiente CDplayer CDP-3000  (Read 19911 times)
RobertoLG
« on: January 03, 2016, 05:08:18 PM »
Twin 16 bit DAC
« Last Edit: March 20, 2019, 11:09:48 PM by RobertoLG »
ProBang2
Re: Gradiente CDplayer CDP-3000
« Reply #1 on: January 03, 2016, 11:04:20 PM »
Hello.
There is no connection from the casing to ground?   ???
But (thin!) hot main wires are direct attached to the metal chassis from back to the front (switch)?  :o
Hmm...
Greetings from Germany,
Hartmut
« Reply #2 on: January 04, 2016, 02:27:10 AM »
Supposed to be a Class II isolation, though it looks more like most electronics from the 1990's in having only a single insulated mains lead, no ground ( though there probably is a grounding lug on the back) and only single insulated wiring inside. They do fail causing shock, but that is not too common before they are replaced with new.
Very likely a standard Sony/Phillips chipset under the board, 3 IC's doing all the work, with a 2k 6116 RAM chip as deinterleaver. Looks like this is the LED/LCD display version, not enough secondaries on the transformer for the VFD versions which use 2 more secondary windings. This has 5V and + and - 12V rails.
