Author Topic: Korad KD3000D power supply question  (Read 9318 times)
mobile1
« on: January 08, 2016, 07:33:42 PM »
I have a Korad KD3000D power supply.
I cannot figure out how to put it into constant current mode.  This is not in the manual.
Does anyone know?
Thank you for your help.
The manual is attached.
ProBang2
Re: Korad KD3000D power supply question
« Reply #1 on: January 09, 2016, 04:19:29 AM »
Hello.
Automatically. "C.V." or "C.C." are depending on the limiting factor (voltage or current).
Example: Using a 12V lightbulb from a car, wired to the PSU.
Set the Korad to 7.00V and 2.200A. (We does not want it too bright or hot...)
Enable the output.
The Korad shows 7.00V and a (in the beginning decreasing) current lower then 2.200A.
After a while, letīs say, 1.600A. The PSU is in "C.V.", the voltage is the limiting factor.
Disable the output.
Change the setting of the current to 1.200A. (Again Voltage 7.00V.)
Enable the output.
The voltage drops down to 4.xxV (a little increasing at the beginning). After a while to 4.30V.
The current stays at 1.200A. The PSU is in "C.C.", now the current is the limiting factor.
Simple, isnīt it?
Why is it so?    Ohmīs law gets you. Every time! Donīt forget: Every load has a resistance.
Further explenations required?
Greetings,
Hartmut
