GTC CM100 1 mA to 100 A Low Current Clamp Meter review and buyers guide
Posted in: Multimeters, Test & Measurement, VideoThis is a review of the GTC CM100 1 mA to 100 A Low Current Clamp Meter
There is a BK Precision equivalent – Mini AC/DC Clamp Meter Model 316: http://www.bkprecision.com/products/m…
You can buy it here: http://astore.amazon.com/m0711-20/det…
The 316 is the perfect Clamp Meter for many electronic applications. Because this meter was designed to measure smaller amounts of current it is ideal for quick non-intrusive current measurements. Auto power off 4 Digit LCD display Low battery indicator 0.49″ Clamp opening Overload protection AC/DC Amp ranges 10A, 80A & 100A 1mA (10A range) & 10mA resolution Measures current between 5% to 100% full scale Measures AC/DC Volts to 600V Measures resistance to 10K ohms One year warranty
GTC 1 mA to 100 Amps AC/DC low current clamp meter is designed to accurately measure current, current leaks (parasitic draws down to 1mA) and electrical loads from 1mA to 100 amp AC/DC and voltages from 0 to 600 AC/DC. The small diameter (½ inch or 13mm) and narrow jaw makes it ideal for use in confined spaces and on small gauge wires. Other features include resistance measurement functions, audible continuity test, display hold and peak detector.
Product Details: Amazon Sales Rank: #4437 in Automotive Color: Grey with Yellow Clamp Brand: GTC Model: CM100
Features:AC/DC current measurement from 0.001 up to 100 A. which makes it a great tool for measuring parasitic draws and AC/DC voltage measurement up to 600 volt
* Small jaw: 1.2 inches (W) x 0.53 inches (D) (300×13.4millimeters) with clamp opening up to 1/2 inch (12.5 millimeters)
* Peak and Data hold functions with one rotary switch operation
* 2 readings per second sampling and continuity check with audible indicator
* Test leads soft carrying deluxe pouch and batteries included
