Major Tech MT22 Multimeter review and buyers guide
Posted in: Multimeters, Test & Measurement, VideoA review of the Major Tech MT22 - an entry level, low cost auto ranging digital multimeter
The MT22 / DT-922 multimeter can be purchased here:
http://astore.amazon.com/m0711-20/det…A list of my multimeters can be purchased here:
http://astore.amazon.com/m0711-20?_en…Description:
The MT22 is a compact meter with double moulded rubber housing and meets the International Standard IEC-61010-1 CAT lll 600V. The large LCD display screen has a white backlight for use in arduous areas. It is a very economical tester ideally suited for everyday use by electricians, electronic technicians as well as the air conditioning industry.
The MT22 compact auto ranging multimeter has a large 2000 count LCD. This meter measures AC and DC voltage up to 600 volts, AC and DC Current up to 10 Amps, Temperature measurement in °C or °F and Resistance, plus a diode test function and continuity buzzer. The meter has a “Clamp-On Adaptor” range which allows the user to use an optional AC and DC clamp adaptor on the meter to increase the current measuring capabilities up to 2000 Amps. Other features include auto power off.
Features: Measures ACV and DCV to 600V MIN/MAX Recordings Temperature between 50 °C to 1000 °C Fused 10A Range Diode Test & Continuity buzzer Data Hold Duty Cycle Resistance measurement to 20MΩ 2000 Count LCD Full Ranges Protection Overmould rubber housing Integrated Test Lead HolderOther Equipment:
Fluke 28-II
Fluke 115
Uni-T UT90A
Uni-T UT90C
LED lights
