Metrix MTX3282 Graphical Digital Data Logging Multimeter review and buyers guide
Posted in: Multimeters, Test & Measurement, VideoThis is the full review for the Metrix MTX3282 Graphical Digital Multimeter
Purchase at my Amazon Store: http://astore.amazon.com/m0711-20?_en…
See this PDF for details:
http://docs-europe.electrocomponents….User manual at
http://www.sgemuhendislik.com/uploads…Product Details – Chauvin Arnoux Metrix MTX3282-COM (RS232 & USB)
Easy to use, the MTX 3282 multimeter from the MTX Mobile product family provides direct single-handed access to its functions, thanks to an electronic measurement switch. Equipped with a large multidirectional LCD screen, it has four 100,000-count digital displays and English/French bilingual menus.
In order to optimise efficiency and safety during use, the “Ampere” and “Volt” measurement terminals allow automatic selection of the appropriate function, in AC+DC mode and default automatic range. The MTX 3282 communicates in all environments thanks to its optical RS232 and USB ports, and its Bluetooth technology. Large multidirectional LCD screen Four 100,000-count digital displays, bargraph, graphic measurement log Voltage: 100kHz specified bandwidth/0.03% basic accuracy Current: 50kHz specified bandwidth/0.08% basic accuracy 3 measurement terminals with automatic selection, “full current autoranging” 8-key electronic measurement switch with direct single-handed access Functions: SPEC, AUTOPEAK, HOLD, AUTOHOLD, REL, SURV, MATH, MEM Frequency measurements up to 2 MHz: duration, duty cycle, event metering “Favourite Measurement” key for physical quantity (conversion or unit) Memorization of 6,500 measurements Supplied with USB + RS232 Kit & Software Supply: LR6 batteries, AA NiMH rechargeable batteries, mains adapter Safety: IEC 61010, Cat. IV 600 V , Cat. III 1,000 V EMC: NF EN 61326-1 Dimensions: 44 x 85 x 180 mm; Weight: 400 g IP51 casing
Dual channel multimeter to measure power
Will auto sense where the leads are plugged in and select the correct measurement.
Option of remote wireless data logging to PC via Bluetooth
