FLIR DM93 Multimeter with data logging Review – Part 1
Posted in: Multimeters, Test & Measurement, VideoThis is a review of the FLIR DM93 4000 / 40 000 count multimeter with data logging and Bluetooth connectivity
You can buy the FLIR DM93 from my Amazon store:
http://astore.amazon.com/m0711-20/det…FLIR DM93 Digital Multimeter Features:
* VFD Mode – Accurately analyze non-sinusoidal waveforms and noisy signals in VFD motors and drive controllers.
* LoZ Mode – Use the Low Impedance Input filter to eliminate ghost voltage readings in long-run applications.
* Continuous Data Recording – Detect intermittent glitches by allowing the FLIR DM93 to collect measurement data unattended over time.
* Bright Dual-LED Worklights – Make your work safer and easier by illuminating dimly lit inspection areas.
* METERLiNKĀ® Compatibility – Embed electrical measurements into thermal images captured by METERLiNK-enabled FLIR infrared cameras.
* Bluetooth Connectivity – Connect to Android devices for remote diagnostics in hard-to-reach and hazardous areas. Also, upload files without the need for special cords.
* Rugged, Shock-Resistant – Double-molded rubber case design enhances reliability on the job site and durability for the long haul.Convenience Features:
* No need to select AC or DC Mode for quick tests
* Backlight features user-configurable timeout
* Large, sharp display is easy to see
* Tool-less battery changing
* Built-in tilt standFor more information:
http://www.flir.com/thermography/amer…
