• FLIR DM93 Multimeter with data logging review – Part 2
    This is a review of the FLIR DM93 4000 / 40 000 count multimeter with data logging and Bluetooth connectivity
  • You can buy the FLIR DM93 from my Amazon store:
    http://astore.amazon.com/m0711-20/det…
    FLIR DM93 Digital Multimeter Features:
    * VFD Mode – Accurately analyze non-sinusoidal waveforms and noisy signals in VFD motors and drive controllers.
    * LoZ Mode – Use the Low Impedance Input filter to eliminate ghost voltage readings in long-run applications.
    * Continuous Data Recording – Detect intermittent glitches by allowing the FLIR DM93 to collect measurement data unattended over time.
    * Bright Dual-LED Worklights – Make your work safer and easier by illuminating dimly lit inspection areas.
    * METERLiNKĀ® Compatibility – Embed electrical measurements into thermal images captured by METERLiNK-enabled FLIR infrared cameras.
    * Bluetooth Connectivity – Connect to Android devices for remote diagnostics in hard-to-reach and hazardous areas. Also, upload files without the need for special cords.
    * Rugged, Shock-Resistant – Double-molded rubber case design enhances reliability on the job site and durability for the long haul.
    Convenience Features:
    * No need to select AC or DC Mode for quick tests
    * Backlight features user-configurable timeout
    * Large, sharp display is easy to see
    * Tool-less battery changing
    * Built-in tilt stand
    For more information:
    http://www.flir.com/thermography/amer…
