ISO-TECH IPM 243 Power Clamp meter 600A AC/DC review
Posted in: Multimeters, Test & Measurement, VideoA review of the ISO-TECH IPM 243 Power Clamp meter 600A AC/DC.
More information here: http://uk.rs-online.com/web/p/power-m…
Chat to Paolo of ISO-TECH here: https://plus.google.com/1177514074461…
ISO-TECH IPM 240 Series Power Clamp Meters
Complete with a full range of diagnostic capabilities including phase sequence, power and power factor, total harmonics distortion and individual harmonics, inrush current and low pass filter, the ISO-TECH IPM 240 Series clamp meters serve as a first line of defense for spot checking and verifying system conditions before deploying more specialized tools or incurring additional costs. They are rated CAT IV 600 V, CAT III 1000 V with voltage measurement up to 1000 V AC/DC. The new innovative navigation system eliminates confusing push buttons, and replaces them with a single joystick allowing the user to select functions directly on the display.
10000 count digital display
Active display backlight and analogue bargraph
VoltSense (Non contact Voltage measurment)
True RMS reading on AC and AC+DC mode
Auto torch-light for viewing easily while clamping conductors
Auto AC/DC 1000 Amp capability and selection (For 245 / RS 754-1249)
Auto AC/DC 600 Amp capability and selection (For 243 / RS 754-1236)
AC 1000 Amp capability (244 / RS 754-1230)
AC 600 Amp capability (242 / RS 754-1233)
Auto AC/DC 1000 Volts capability and selection for all models (242, 243, 244, 245)
Auto Ohms/Continuity/Diode selection
100kΩ resistance capability
Continuity beeper
Frequency counter
Power and power factor measurement
Total harmonics distortion and % harmonics 1 to 25
Capacitance capability
°C / °F temperature measurement function ( For 242/245 only)
DCμA for flame rod testing ( For 242 only)
Inrush current
DCA Auto-zeroing key (For 243/245 only)
Peak HOLD
MIN/MAX HOLD
Smart Data HOLD
Phase rotation indication
Low pass filter
Auto power off
Safety Standard: IEC 61010-1 CAT IV 600V / CAT. III 1000V
Supplied with
IPM 240 series power clamp meter
Test leads set (one black, one red)
Temperature probe (For 242/245 only)
User manual
Carrying case
9V alkaline battery (supplied and pre-installed)
