Fluke 115 TRMS Multimeter review – Part 1
Posted in: Multimeters, Test & Measurement, VideoFluke 115 TRMS Multimeter Review
A review of the Fluke 115 True RMS 6000 count electricians multimeter.
Buy it here: http://www.tester.co.uk/fluke-115-tec…
Video sponsor, Pass Ltd – their websites:
http://www.tester.co.uk/?cmid=QmhzQjc… – Test Equipment and Test-meter suppliers and
http://www.calibrate.co.uk – Calibration and service of test equipment
================================================= Details:
http://www.fluke.com/Fluke/usen/Digit…
Designed by electricians. Engineered by Fluke.
For general purpose electrical and electronic test requirements, the Fluke 115 true-rms digital multimeter provides the perfect answer. Its simple operation, compact design and ease of use makes it perfect for quick verifications and field service use.
The Fluke 115 displays true-rms voltage and current readings with 6000 count resolution, tests diodes, frequency, continuity and capacitance and provides Min/Max/Average readings to record signal fluctuations. A large white LED backlight aids work in poorly lit areas. Its easy-open battery access door makes battery changes a snap.
Fluke 115 multimeters are independently tested for safe use in CAT III 600V environments.
And check out other members of the Fluke 110 family: the Fluke 113 Utility Multimeter, the Fluke 114 Electrical Multimeter, the Fluke 116 HVAC Multimeter and the Fluke 117 Commercial Electrician’s Multimeter.Also check out the Fluke 114 Electrical Multimeter, the Fluke 116 HVAC Multimeter with Temperature and Microamps, and the Fluke 117, the Electrician’s Multimeter with Non-contact voltage. Large white LED backlight to work in poorly lit areas Resistance and continuity Frequency and capacitance Maximum Voltage ac/dc 600V 10A ac/dc current measurement (20 A overload for 30-seconds max) Min/Max/Average to record signal fluctuations CAT III 600 V safety rated
