• Vichy VC97 vs Victor VC97 Multimeter review – Part 1
    A review and side by side comparison of the Vichy VC97 vs Victor VC97 Multimeters.
  • These are both “cheap” sub $30, 4000 count multimeters.
    Vichy VC97 description:
    VC97 3 3/4 Auto range digital multimeter. It has the following features: Auto range digital multimeter with new type holster, Large LCD makes the reading clearly, Strong antimagnetic and anti-jamming performance, Full function protection, Unit symbol display, very easy to reading. 100% brand new, of high quality and durable.
    Specification: • Place of Origin: Guangdong, China (Mainland) • Brand Name: Vici • Model Number: VC97 • Measuring Current Range: 0-20A • Measuring Voltage Range: 0-1000V • Measuring Resistance Range: 0-40MΩ • Measuring Capacitance Range: 0-200uF • Measuring Inductance Range: 0 • Operating Temperature: 23±5°C • Dimensions: 185mm X 93mm X 35mm • Frequency: 0-30MHz • Temperature: -40℃-1000℃
    Package:
    (1) Content: • 1* New Vichy VC97 3 3/4 Auto Range Digital Multimeter
    (2) Gross Weight: Approx.0.51kg
    Victor V97 specs:
    Model VC97 – 3 3/4 Auto-range Digital Multimeter
    Auto range (with manual range button)
    3999 counts max.
    Unit symbol display
    Data hold
    Relative mode
    Low battery indication
    Auto power off
    Full overload protection
    Wrong input alert
    Fuse protection at 10A current range
    Protective holster (rubber boot)
    Frequency response: 40Hz ~ 400Hz
    DC voltage: 400mV/4V/40V/400V/1000V (± 0.5%)
    AC voltage: 4V/40V/400V/700V (± 0.8%)
    DC current: 400µA/4mA/40mA/400mA/10A (± 0.8%)
    AC current: 400µA/4mA/40mA/400mA/10A (± 1.0%)
    Resistance: 400Ω/4k/40k/400k/4MΩ/40MΩ (± 0.8%)
    Capacitance: 4nF/40nF/400nF/4µF/40µF/200µF (± 2.5%)
    Frequency: 10Hz/100Hz/1kHz/10kHz/100kHz/1MHz/30MHz (± 0.5%)
    Duty cycle measurement
    Temperature: -40°C ~1000°C (±0.75%)
    Diode check
    Triode check
    Continuity test (audible)
    Power source: AAA (1.5V) x 2
    Dimension: 190 x 88.5 x 27.5mm
    Weight: approx. 320g (including battery)
