Agilent U1232A Multimeter review – Part 2
Posted in: Multimeters, Test & Measurement, Video -
A look at the smoothing feature, noisy readings, teardown, consumption and mains measurement.
Buy it here: http://astore.amazon.com/m0711-20/det…
Video sponsor, Pass Ltd – their websites:
http://www.tester.co.uk/?cmid=QmhzQjc… – Test Equipment and Test-meter suppliers and
http://www.calibrate.co.uk/?cmid=Qmhz… – Calibration and service of test equipment
================================================= Key Features & Specifications Built-in LED torchlight to illuminate test area Flashing backlight as visual alert during continuity tests in dim areas Data logging capability (stores up to 10 readings) IR connectivity to transfer data to PC for record Basic measurements (Voltage, Current1, Resistance, Diode, Capacitance, Frequency) Auxiliary temperature measurement using K-type thermocouple* Compatible with U1177A IR-Bluetooth adapter for remote monitoring & data logging 6000 count 0.5% basic DC accuracy
*Optional U1586B temperature module is require
