  • Single Phase Power Quality Part 3 – Power Factor Correction
    February 23, 2015 Posted in: Video
    Single phase power quality - theory, analogies and practical demonstrations
  • Part 3 of the tutorial on single phase power quality, it covers some theory, analogies and practical demonstrations on the following topics:
    * Power factor in linear loads – Real power (Watts), active power, true power, apparent power (VA – Volt Amps), reactive power (VAR- Volt Amps Reactive), phase angle, inductive loads, capacitive loads, leading and lagging power factor.
    * Power factor in non-linear loads – harmonics, total harmonic distortion (THD), displacement power factor (DPF), distortion power factor (dPF), true power factor, total power factor.
    * Power factor correction – passive, active, dynamic, harmonic filtering, synchronous condensers / capacitors, application of capacitors for power factor correction.
    * Power grid stability – Use of VAR (reactive power) to stabilise grid voltage.
    * Negative and positive effects of large solar (PV) power generation on the grid.
    * Do the power factor correction devices for your home save you money?
    Watch the entire playlist here:  http://www.mjlorton.com/ac-power-and-electrics/
    * Quick demonstration of some tools to measure power quality:
    Siglent SHS 1102 Oscilloscope – http://www.tester.co.uk/siglent-shs11…
    HT Instruments HT2209 – http://www.ht-instruments.com/en/prod…
    Fluke 345 – http://en-us.fluke.com/products/power…
    Fluke 43B – http://www.fluke.com/Fluke/caen/Power…
    Power factor calculator – http://www.rapidtables.com/calc/elect…
    Reactive Power Control in Utility-Scale PV – http://solarprofessional.com/articles…
    Inverter Reactive Power Compensation – http://www.blueoakenergy.com/blog/inv…
    Meet Solar’s Imaginary Friend, Reactive Power – http://www.renewableenergyworld.com/r…
    Power Factor Correction Scam Review – http://www.nlcpr.com/Deceptions1.php
    What are non-linear loads and why are they a concern today?
    http://www.mirusinternational.com/dow…
    Power factor Wiki – http://en.wikipedia.org/wiki/Power_fa…
    Synchronous Condenser (sometimes called a synchronous capacitor or synchronous compensator) – http://en.wikipedia.org/wiki/Synchron…
    • ISO-TECH-IPS303DD
      ISO-TECH-IPS303DD
      Shop Now
  • If you're unable to see the products related to this post it's very likely that you have your browser's ad-blocker enabled. Please support content creation on MJLorton.com by turning off your ad-blocker. Thanks, Martin
