Spectrum Analysis Data
Posted in: Research and DataOngoing research and development to find a full spectrum light source to test solar panels
This data has been captured with a UPRtek MK350 Spectrometer. This is part of ongoing research and development to find a full spectrum light source to test solar panels. New data will be added that might be of help if you are looking for a particular light source for your own needs. The spectral distribution and CRI rating are shown. CCT, Peak wave length, CIE1931 and CIE1976 are also shown. Don’t place too much reliance on the Lux reading as the measurement range was not consistent across the light sources.
1. Clear Winter Day – Noon
2. Clear Winter Day – Morning
3. Overcast Winter Day
4. Reflection Off Snow
5. Bi Color 500 LED Light Panel By Fancierstudio 500CHS
6. Roleadro LED 150w High Bay LED Light Fixture Industrial Light
7. Howard Lighting IHAC22E-400-MH-4T 400W High Bay w/ Lamp & 22" Acrylic Reflector
8. Nitecore Tiny Monster TM26 4000 Lumen Search Light
9. Miracle-Gro AeroGarden Harvest Light
10. MarsHydro MARSII 1600 Led Grow Light Full Spectrum High Penentration Led Grow Lamp Light
11. MarsHydro Mars300 Mars600 LED Grow Light
12. LEDwholesalers Dimmable Ultra Thin Glare-Free Edge-Lit LED Light Panel
13. Univivi U06R WideAngle Long Range 130 Feet 6pcs LED Array Lights IR Illuminator
14. 6-LED UV Lamp for Curing LOCA UV GLUE from Octopus Glue
15. TaoTronics E27 Plant Grow Lights
16. Designers Edge L1312 5x1W Portable Ecozone LED Work Light
17. Designers Edge L1315 63-LED 1681-Lumen Portable Ecozone LED Work Light
18. Designers Edge L1306 108-LED Portable Bright LED Workshop Lighting
19. Designers Edge L-2004 65-Watt Fluorescent Portable Worklight
20. NatureBright SunTouch Plus Light and Ion Therapy Lamp
21. Voltec 08-00212 250-Watt Portable Halogen Worklight
22. Ledwholesalers 56 Watt LED Waterpoof Outdoor Security Floodlight
23. LOHAS 100W LED Chip Cool White Bulb High Power Energy Saving Lamp Chip
24. LOHAS 100W LED Chip Cool White Bulb High Power Energy Saving Lamp Chip + 50mm Reflector Collimator Base Housing
25. Aquatic Life 150 Watt Metal Halide Light
26. Philips 248872 Soft White 65-Watt BR30 Indoor Flood Light Bulb
27. GE 23 Watt Energy Smart CFL - 100 Watt
28. Smart & Green Lighting LED Lighting, Suqare LED Recessed Ceiling light, 25W 1850LM 6000k (Day White)
29. GLW 50w Remote Control RGB Flood Light
30. CREE LED 98w + 44mm Lens, 50mm Reflector Collimator Base Housing & Fixed bracket
31. Yuji BC Series High CRI COB LED – 400HS – 100W
32. DIY Grow Light by Bud Craig
