Thermal Cameras Buyers Guide
Posted in: Consumer ReviewsIn this video series I provide guidelines on buying thermal cameras.
1. Part 1 - Specifications and criteria on choosing a thermal cameraIn this video series I provide some guidelines on buying a thermal camera.
Support my blogging and purchase your thermal camera here:
http://astore.amazon.com/m0711-20?_en…These are longer, more detailed videos to help the prospective
buyer select the correct thermal camera for their needs.Be selective in the videos you need to watch with this guide:
* Part 1 – Specifications and criteria on choosing a thermal camera:
Overview and pricing of the 12 thermal cameras. Resolution, field of view, sensitivity, distance to spot ratio and accuracy, frame rate,
analysis and reporting software, collaboration, focus, IR Blending, temperature measurement range and MSX technologies.* Part 2 – A demonstration and comparison of camera sensitivity and field of view. A more detailed overview of the 12 sample thermal cameras.
* Part 3 – Thermal camera tests and the final comparative results.
Thermal Cameras tested in this buyers guide:
* Seek Thermal Compact for Android and iPhone
http://www.thermal.com/thermal-cameras/* FLIR ONE for Android and iPhone
http://www.flir.com/flirone/content/?…* Seek Thermal Reveal
http://www.thermal.com/thermal-cameras/* FLIR C2
http://www.flir.com/Instruments/displ…* Fluke VT02
http://en-us.fluke.com/products/visua…* Fluke VT04
http://en-us.fluke.com/products/visua…* FLIR TG165
http://www.flir.com/instruments/conte…* HT THT45
http://us.ht-instruments.com/en-us/pr…* Fluke Ti90
http://en-us.fluke.com/products/infra…* Fluke TiS10
http://en-us.fluke.com/products/infra…* FLIR E4
http://www.flir.com/E6/* Opgal Therm-App HT
http://therm-app.com/therm-app-thermo…* How to buy a thermal imager
* Thermal camera review
* Thermal imager review -
2. Part 2 - A demonstration and comparison of camera sensitivity and field of viewIn this video series I provide some guidelines on buying a thermal camera.
3. Part 3 - Thermal camera tests and the final comparative results.In this video series I provide some guidelines on buying a thermal camera.
1. Thermal Camera Test Results
2.1 Spec Comparisons 1
Make and Model Price ($) (November 2015) Resolution Total Pixels Sensitivity (NETD) Temperature Range (°C) Opgal Therm-App TH 1,900 384x288 110592 <0.07 °C 0 to 200 HT Instruments THT45 995 80x80 6400 <0.1 °C -20 to 350 Fluke TiS10 1,200 80x60 4800 ≤0.15 °C (150 mK) -20 to 250 Fluke Ti90 1,350 80x60 4800 ≤0.15 °C (150 mK) -20 to 250 Fluke VT04 420 31x31 961 Not Specified -10 to 250 Fluke VT02 (Discontinued) 500 Not Specified - Less than VT04 Not Specified - Less than VT04 Not Specified -10 to 250 FLIR E4 800 80 × 60 4800 ≤0.15 °C (150 mK) -20 to 250 FLIR TG165 400 80x60 4800 ≤0.15 °C (150 mK) -25 to 380 FLIR One (Android / iOS)) 250 160 × 120 19200 ≤0.1 °C (100 mK) -20 to 120 FLIR C2 700 80x60 4800 ≤0.1 °C (100 mK) -10 to 150 Seek Compact (Android / iOS) 250 / 205 206x156 32136 Not Specified -40 to 330 Seek CompactXR (Android / iOS) 290 / 226 206x156 32136 -40 to 330 Seek Reveal 352 206x156 ? 32136? -40 to 330 2.2 Spec Comparisons 2
Make and Model Non uniformity correction (NUC) Distance to spot ratio (D:S) Instantaneous field of view / spatial resolution (IFOV) milli Radians IR spectrum (μm) Thermal camera field of view (angles) Opgal Therm-App TH Shutterless 100:1 2.5 7.5 to 14 55° x 41° (6.8mm lens) HT Instruments THT45 Shutter Not Given 3.78 8 to 14 17° x 17° (9mm lens) Fluke TiS10 Shutter 128:1 7.8 7.5 to 14 35.7 ° x 26.8 ° Fluke Ti90 Shutter Not Specified 5.6 9 to 15 19.5 ° x 26 ° Fluke VT04 Shutterless ? Not Specified Not Specified 6.5 to 14 28° x 28° Fluke VT02 (Discontinued) Shutterless ? Not Specified Not Specified 6.5 to 14 20° x 20° FLIR E4 Shutter Not Specified 10.3 7.5 to 13 45° × 34° FLIR TG165 Shutter ? 24:1 Not Specified 8 to 14 50° x 38.6° FLIR One (Android / iOS)) Shutter Not Specified Not Specified Not Specified Not Specified FLIR C2 Shutter Not Specified Not Specified 7.5 to 14 41° × 31° Seek Compact (Android / iOS) Shutter Not Specified Not Specified 7.2 to 13 36° Seek CompactXR (Android / iOS) 7.2 to 13 20° Seek Reveal Shutter Not Specified Not Specified 7.2 to 13 ? 36° 2.3 Spec Comparisons 3
Make and Model Thermal camera accuracy (degrees C) Minimum focal distance Focus type Frame rate Actual camera frame rate performance test Opgal Therm-App TH +/- 2°C or 2% (at 25°C) 0.2 m Manual 8.7 Hz Stills - Very Good, Video - Ok HT Instruments THT45 +/- 2°C or 2% (at 25°C) 0.5 m Manual 50 Hz Stills - Excellent, Video - Excellent Fluke TiS10 +/- 2°C or 2% (at 25°C) 0.45 m (1.5 ft) Fixed focus 9 Hz Ok to Good Fluke Ti90 +/- 2°C or 2% (at 25°C) 0.46 m (18 in) Fixed focus 9 Hz Very Good Fluke VT04 +/- 2°C or 2% (at 25°C) ~23 cm (9 in) Focus free ~9 Hz (Not Specified) Bad Fluke VT02 (Discontinued) +/- 2°C or 2% (at 25°C) ~23 cm (9 in) Focus free ~9 Hz (Not Specified) Very Bad FLIR E4 +/- 2°C or 2% (at 25°C) 0.5 m (1.6ft) Focus Free 9 Hz Good FLIR TG165 +/- 1.5°C or 1.5% (at 25°C) Not Specified Focus Free 9 Hz Poor FLIR One (Android / iOS)) Not Specified Not Specified Focus Free ~9 Hz (Not Specified) Stills - Poor, Video - Poor FLIR C2 +/- 2°C or 2% (at 25°C) Thermal: 0.15 m (0.49 ft.) MSX: 1.0 m (3.3 ft.) Focus Free 9 Hz Poor Seek Compact (Android / iOS) Not Specified Not Specified Manual <9 Hz (Not Specified) Stills - Poor, Video - Poor Seek CompactXR (Android / iOS) <9 Hz (Not Specified) Not Tested Seek Reveal Not Specified Not Specified Focus Free < 9 Hz Poor 2.4 Spec Comparisons 4
Make and Model Storge Internal / External Battery type / size Battery Run Time Charge method IR palette temperature span Opgal Therm-App TH Phone memory Phone battery Phone battery Phone Charger Auto, Manual HT Instruments THT45 External - Micro SD card 8GB Rechargeable Li-ION, 3,7V 2000mAh 4 hours External adapter 100/240VAC (50/60Hz)/5VDC Auto, Lock Fluke TiS10 Internal 4 GB / optional 4 GB micro SD Rechargeable Li-ION 4+ hours External adapter 100/240VAC (50/60Hz)/15VDC Auto, Manual Fluke Ti90 External - 4 Gb SD or 8 Gb wireless SD Rechargeable Li-ION 4+ hours External adapter 100/240VAC (50/60Hz)/15VDC Auto, Manual Fluke VT04 External - 4 GB micro SD Rechargeable Li-ION 8 hours Micro USB Auto Fluke VT02 (Discontinued) External - 4 GB micro SD 4 x AA cells 8 hours NA Auto FLIR E4 Internal - 173 MB Rechargeable Li-ION 4 hours Micro USB Auto, Lock FLIR TG165 External - 8 GB micro SD Rechargeable Li-ION, 3.7V, 2600mAh 8 hours Micro USB Fixed FLIR One (Android / iOS)) Phone memory Rechargeable Li-ION, 350 mAh 1 Hour Micro USB Auto, Lock FLIR C2 Internal - 165 MB Rechargeable Li-ION, 3.7V 2 Hour Micro USB Auto, Lock Seek Compact (Android / iOS) Phone memory Phone battery Phone dependant Phone Charger No Seek CompactXR (Android / iOS) No Seek Reveal External - 512 MB micro SD Rechargeable Li-ION 11 Hours + Micro USB No 2.5 Spec Comparisons 5
Make and Model Temperature Level of IR palette span Interchangable lens Laser Targeting Size (mm) Weight Opgal Therm-App TH Auto Yes No 55 x 65 x 40 (2.16 x 2.55 x 1.57in) 123 grams / 4.33 ounces HT Instruments THT45 Fixed No Yes 224 x 77 x 96 500 grams Fluke TiS10 Auto, Manual No No 267 x 101 x 145 (10.5 x 4.0 x 5.7 in) 720 grams (1.6 lb) Fluke Ti90 Auto, Manual No No 284 x 86 x 130 (11.2 in x 3.4 in x 5.3 in) 730 grams (1.6 lb) Fluke VT04 Auto No No 210 x 75 x 55 (8.3 in x 3 in x 2.2 in) 344 grams Fluke VT02 (Discontinued) Auto No No 210 x 75 x 55 (8.3 in x 3 in x 2.2 in) 374 grams FLIR E4 Fixed No No 244 × 95 × 140 (9.6×3.7×5.5in.) 575 grams FLIR TG165 Fixed No Yes 186 x 55 x 94 (7.3 x 2.2 x 3.7 in) 313 grams (11 ounces) FLIR One (Android / iOS)) Auto No No 72 x 26 x 18 (2.8 in x 1 in x 0.7 in) 78 grams (2.75 ounces) FLIR C2 Fixed No No 125 × 80 × 24 (4.9 × 3.1 × 0.94 in.) 130 grams (0.29 lb.) Seek Compact (Android / iOS) No No No 47 x 20 x 23 12 grams (0.4 ounces) Seek CompactXR (Android / iOS) No No No 47 x 20 x 23 12 grams (0.4 ounces) Seek Reveal No No No 127 x 62 x 34 183 grams (64. ounces) 2.6 Spec Comparisons 6
Make and Model IP Rating Complete unit / Phone required Display resolution Visible Camera Resolution IR Fusion / IR Blending / MSX technology (Image Edging) Opgal Therm-App TH IP54 Android Phone Phone Screen Resolution Phone Camera Blending, Edging in software HT Instruments THT45 IP50 Complete Unit - Industrial hand held 320x240 1.3 Mega Pixel Picture in Picture Blending Fluke TiS10 IP54 Complete Unit - Industrial hand held 320x240 5 Mega Pixel IR-Blending available in software Fluke Ti90 IP54 Complete Unit - Industrial hand held Not Specified 2 Mega Pixel IR-Blending available in software Fluke VT04 Not Specified Complete Unit - Industrial hand held Not Specified Not Specified IR- heat map blending Fluke VT02 (Discontinued) Not Specified Complete Unit - Industrial hand held Not Specified Not Specified IR- heat map blending FLIR E4 Not Specified Complete Unit - Industrial hand held 320 × 240 0.3 Mega Pixel MSX, IR Blending FLIR TG165 Not Specified Complete Unit - Industrial hand held 176 x 220 NA NA FLIR One (Android / iOS)) Not Specified Unit clipped to phone data port Phone Screen Resolution 0.3 Mega Pixel MSX FLIR C2 Not Specified Phone styled complete unit 320 × 240 0.3 Mega Pixel MSX Seek Compact (Android / iOS) Not Specified Unit clipped to phone data port Phone Screen Resolution Phone Camera dependant Swip blending Seek CompactXR (Android / iOS) Not Specified Unit clipped to phone data port Phone Screen Resolution Phone Camera dependant Swip blending Seek Reveal Not Specified Flashlight styled complete unit 240x320 No No 2.7 Spec Comparisons 7
Make and Model Video recording Image types Image with temperature information Image with radiometric / meta data Analysis and reporting software Opgal Therm-App TH Yes JPEG Yes Yes Yes - IRT Cronista HT Instruments THT45 Yes - MP4, with Audio using included mic JPEG No Yes - JPG THTLink Fluke TiS10 No IS2 Yes Yes - IS2 SmartView® Fluke Ti90 No BMP, JPEG, IS2 BMP, JPEG Yes - IS2 SmartView® Fluke VT04 No BMP, IS2 BMP Center measurement, Hot and Cold Markers - IS2 SmartView® Fluke VT02 (Discontinued) No IS2 No Center measurement (Hot & Cold Markers in SW) - IS2 SmartView® FLIR E4 No JPEG JPEG Yes - JPEG FLIR Tools FLIR TG165 No BMP BMP No FLIR Tools FLIR One (Android / iOS)) Yes - MOV JPEG Yes - JPEG Yes - JPEG FLIR Tools FLIR C2 No (Can stream video) JPEG JPEG Yes - JPEG FLIR Tools Seek Compact (Android / iOS) Yes - MP4 JPEG JPEG No No Seek CompactXR (Android / iOS) Yes - MP4 JPEG JPEG No No Seek Reveal No PNG PNG No No 2.8 Spec Comparisons 8
Make and Model Zoom Sharing and Collaboration From Device Display size (Inches) Tripod mount Opgal Therm-App TH Continuous digital zoom using touchscreen Email, Texting, Dropbox from phone Phone Display Yes HT Instruments THT45 Digital x1 - x32 No 2.8 Yes Fluke TiS10 No Fluke Connect wireless (integrated) 3.5 (landscape) Yes (Non standard) Fluke Ti90 No Fluke Connect wireless (SD Card) 3.5 (portrait) Yes (Non standard) Fluke VT04 No No 2.25 Yes Fluke VT02 (Discontinued) No No 2.25 Yes FLIR E4 No No 3 No FLIR TG165 No No 2 Yes FLIR One (Android / iOS)) No Easy sharing (Twitter, Facebook, Instagram, e-mail, SMS, etc.) Phone Display Size No FLIR C2 No No 3 No Seek Compact (Android / iOS) Yes - Digital email, SMS, etc from phone Phone Display Size No Seek CompactXR (Android / iOS) Yes - Digital email, SMS, etc from phone Phone Display Size No Seek Reveal No No 2.25 Yes (Non standard) These are longer, more detailed videos to help the prospective
- * Seek Thermal Compact for Android and iPhone: http://www.thermal.com/thermal-cameras/
- * FLIR ONE for Android and iPhone: http://www.flir.com/flirone/content/?…
- * Seek Thermal Reveal: http://www.thermal.com/thermal-cameras/
- * FLIR C2: http://www.flir.com/Instruments/displ…
- * Fluke VT02: http://en-us.fluke.com/products/visua…
- * Fluke VT04: http://en-us.fluke.com/products/visua…
- * FLIR TG165: http://www.flir.com/instruments/conte…
- * HT THT45: http://us.ht-instruments.com/en-us/pr…
- * Fluke Ti90: http://en-us.fluke.com/products/infra…
- * Fluke TiS10: http://en-us.fluke.com/products/infra…
- * FLIR E4: http://www.flir.com/E6/
- * Opgal Therm-App HT: http://therm-app.com/therm-app-thermo…
