Tutorial: 555 Timer, PWM LED Driver and Latched Switch – Part 1
Posted in: VideoTutorial series on the 555 timer and demonstration on how it works as a PWM LED Driver and Latched Switch.
This is also a follow-up to “A Look Inside #6 – Kelty LumaTech Cree LED Lantern”
http://youtu.be/gopsOieG7wsIn the demonstration I need to look at a leakage / quiescent current to see if it can be reduced.
Topics coved in this video:
* Some background and history on the 555 timer.
* Pin layout and description of the 555 timer DIP IC
* Explanation on how the comparator op amps work inside the 555 timer.
* Explanation on how the RS Flip Flop works and the its logic
* An explanation and demonstration of the 555 timer as a latched switch.
* An explanation and demonstration of the 555 timer as a PWM (pulse width modulated) LED driver / dimmer circuit.
* A look at transistors and a Darlington pair.
* A look at how we can improve the quiescent / q-point current of the circuit.
* 555 timer tutorial
* Monostable and astable multivibrator
