Two-Way Radio Handsets Tested – The Results
Posted in: Consumer ReviewsTesting 10 two-way radios - walkie-talkies / HTs Handy Talkies
1. Two Way Radio Review / Range Tests - Part 1Radios Tested:
Motorola RMM2050 MURS VHF
Midland GXT950VP4 FRS / GMRS
TYT MD-380 UHF Analog / Digital
Baofeng UV-82HP UHF / VHF
ICOM IC-F4001 UHF
Midland 75-822 AM CB
Baofeng BF-UVB2PLUS UHF / VHF
Midland LXT600VP3 FRS / GMRS
AnyTone Termn-8R UHF / VHF 5W
Tera TR-505 UHF / VHFTests conducted:
* Vehicle to vehicle (car to car) – neighbourhood watch
* Line of sight
* Urban mix
* Through trees
* Over hills
* In a building
* Mobile to hand held radio -
2. Two Way Radio Review / Range Tests - Part 2Radios Tested:
ICOM IC-F4001 UHF
* Line of sight
* Urban mix
* Through trees
* Over hills
* In a building
1. Overall Rankings
2.1 Specs
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts)
(actual measured power)AnyTone Termn-8R UHF / VHF Analog 25 5 / 6 (4.6 / 6.2) Baofeng BF-UVB2PLUS UHF / VHF Analog 25 4 / 4 (4 / 5.4) Baofeng UV-82HP UHF / VHF Analog 25 7 / 8 (5.3 / 7.3) ICOM IC-F4001 UHF Analog 25 / 12.5 4 Midland 75-822 AM Analog 4 4 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 Midland LXT600VP3 UHF Analog 25 5 Motorola RMM2050 MURS VHF Analog 20 2 TYT MD-380 UHF Digital / Analog 12.5 5 (4.1) Tera TR-505 UHF / VHF Analog 11.25 / 25 4 / 4 (4.1 / 4.8) 2.2 Licensing
Two-Way Radio Make and Model Type Radio of License Required FCC Approved Use AnyTone Termn-8R None / GMRS / HAM / Commercial MURS (part 95J) / GMRS (part 95A) / HAM (part 15B) / Commercial (part 90) Baofeng BF-UVB2PLUS HAM None Baofeng UV-82HP HAM None ICOM IC-F4001 Commercial Commercial (part 90) / HAM (part 15B) Midland 75-822 None CB (part 95D) Midland GXT-950VP4
(now replaced by GXT-1050VP4)GMRS FRS (part 95B) / GMRS (part 95A) Midland LXT600VP3 GMRS FRS (part 95B) / GMRS (part 95A) Motorola RMM2050 MURS None MURS (part 95J) TYT MD-380 HAM None Tera TR-505 None / GMRS / HAM MURS (part 95J) / GMRS (part 95A) / HAM
3.1 Test 1 – Over the Hills
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Over the Hill (miles) Test Rank Baofeng UV-82HP VHF Analog 25 8 0.9 1 TYT MD-380 UHF Analog 12.5 5 0.85 2 TYT MD-380 UHF Digital 12.5 5 0.85 3 Baofeng UV-82HP UHF Analog 25 7 0.8 4 TYT MD-380 UHF Digital 12.5 1 0.8 5 Motorola RMM2050 MURS VHF Analog 11.25 2 0.8 6 Motorola RMM2050 MURS VHF Analog 20 2 0.8 7 Baofeng BF-UVB2PLUS VHF Analog 25 4 0.8 8 ICOM IC-F4001 UHF Analog 25 4 0.8 9 AnyTone Termn-8R UHF Analog 25 5 0.8 10 Baofeng BF-UVB2PLUS UHF Analog 25 4 0.8 11 Midland 75-822 AM Analog 4 4 0.8 12 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 NA NA Midland LXT600VP3 UHF Analog 25 5 NA NA Midland LXT600VP3 UHF Analog 12.5 0.5 NA NA Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 12.5 0.5 NA NA
3.2 Test 2 – Through the Trees
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Through the Trees (miles) Test Rank Baofeng UV-82HP VHF Analog 25 8 1.05 1 Motorola RMM2050 MURS VHF Analog 11.25 2 0.58 2 Motorola RMM2050 MURS VHF Analog 20 2 0.58 3 TYT MD-380 UHF Digital 12.5 5 0.58 4 Baofeng UV-82HP UHF Analog 25 7 0.58 5 AnyTone Termn-8R UHF Analog 25 5 0.58 6 Baofeng BF-UVB2PLUS VHF Analog 25 4 0.58 7 Baofeng BF-UVB2PLUS UHF Analog 25 4 0.58 8 TYT MD-380 UHF Digital 12.5 1 0.44 9 TYT MD-380 UHF Analog 12.5 5 0.44 10 ICOM IC-F4001 UHF Analog 25 4 0.44 11 Midland LXT600VP3 UHF Analog 25 5 0.44 12 Midland 75-822 AM Analog 4 4 0.44 13 Midland LXT600VP3 UHF Analog 12.5 0.5 0.3 14 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 NA NA Midland GXT-950VP4
3.2 Test 3 – Urban Mix
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Urban Mix (miles) Test Rank Baofeng UV-82HP VHF Analog 25 8 1.9 1 TYT MD-380 UHF Digital 12.5 5 1.9 2 TYT MD-380 UHF Analog 12.5 5 1.75 3 Tera TR-505 VHF Analog 25 4 1.75 4 Motorola RMM2050 MURS VHF Analog 11.25 2 1.5 5 Motorola RMM2050 MURS VHF Analog 20 2 1.5 6 Baofeng UV-82HP UHF Analog 25 7 1.5 7 AnyTone Termn-8R UHF Analog 25 5 1.5 8 Baofeng BF-UVB2PLUS VHF Analog 25 4 1.5 9 Baofeng BF-UVB2PLUS UHF Analog 25 4 1.5 10 Tera TR-505 UHF Analog 25 4 1.5 11 TYT MD-380 UHF Digital 12.5 1 0.63 12 ICOM IC-F4001 UHF Analog 25 4 0.63 13 Midland LXT600VP3 UHF Analog 25 5 0.63 14 Midland LXT600VP3 UHF Analog 12.5 0.5 0.63 15 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 0.63 16 Midland 75-822 AM Analog 4 4 0.63 17 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 12.5 0.5 0.5 18
3.3 Test 4 – Vehicle to Vehicle
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Vehicle to Vehicle (miles) Test Rank Baofeng UV-82HP VHF Analog 25 8 1 1 TYT MD-380 UHF Digital 12.5 5 1 2 TYT MD-380 UHF Analog 12.5 5 1 4 Baofeng UV-82HP UHF Analog 25 7 1 3 AnyTone Termn-8R UHF Analog 25 5 1 5 Baofeng BF-UVB2PLUS VHF Analog 25 4 1 7 Baofeng BF-UVB2PLUS UHF Analog 25 4 1 8 ICOM IC-F4001 UHF Analog 25 4 1 6 Motorola RMM2050 MURS VHF Analog 11.25 2 NA NA Motorola RMM2050 MURS VHF Analog 20 2 NA NA TYT MD-380 UHF Digital 12.5 1 NA NA Midland LXT600VP3 UHF Analog 25 5 NA NA Midland LXT600VP3 UHF Analog 12.5 0.5 NA NA Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 NA NA Midland 75-822 AM Analog 4 4 NA NA Midland GXT-950VP4
3.4 Test 5 – Inside Building
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Inside Building (floors) Test Rank TYT MD-380 UHF Digital 12.5 1 18 1 TYT MD-380 UHF Digital 12.5 5 18 2 Baofeng UV-82HP UHF Analog 25 7 18 3 Motorola RMM2050 MURS VHF Analog 11.25 2 18 4 TYT MD-380 UHF Analog 12.5 5 18 5 Motorola RMM2050 MURS VHF Analog 20 2 18 6 AnyTone Termn-8R UHF Analog 25 5 18 7 ICOM IC-F4001 UHF Analog 25 4 18 8 Baofeng UV-82HP VHF Analog 25 8 18 9 Baofeng BF-UVB2PLUS UHF Analog 25 4 18 10 Baofeng BF-UVB2PLUS VHF Analog 25 4 18 11 Midland LXT600VP3 UHF Analog 25 5 18 12 Midland LXT600VP3 UHF Analog 12.5 0.5 18 13 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 9 14 Midland 75-822 AM Analog 4 4 9 15 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 12.5 0.5 7 16
3.5 Test 6 – Line of Sight
Two-Way Radio Make and Model Radio Band Mode Bandwidth (kHz) Radio Power (Watts) Line of Sight Range (miles) Test Rank TYT MD-380 UHF Digital 12.5 5 7.3 1 TYT MD-380 UHF Digital 12.5 1 7.3 2 Tera TR-505 UHF Analog 25 4 7.3 3 Baofeng UV-82HP VHF Analog 25 8 7.3 4 Baofeng UV-82HP UHF Analog 25 7 7.3 5 TYT MD-380 UHF Analog 12.5 5 7.3 6 ICOM IC-F4001 UHF Analog 25 4 7.3 7 AnyTone Termn-8R UHF Analog 25 5 7.3 8 Baofeng BF-UVB2PLUS VHF Analog 25 4 7.3 9 Baofeng BF-UVB2PLUS UHF Analog 25 4 7.3 10 Motorola RMM2050 MURS VHF Analog 11.25 2 6.2 11 Motorola RMM2050 MURS VHF Analog 20 2 6.2 12 Midland GXT-950VP4
(now replaced by GXT-1050VP4)UHF Analog 25 5 5 13 Midland LXT600VP3 UHF Analog 25 5 4.1 14 Midland LXT600VP3 UHF Analog 12.5 0.5 1.55 15 Midland 75-822 AM Analog 4 4 1.55 16 Midland GXT950VP4 UHF Analog 12.5 0.5 0.5 17
