USB Power Banks Tested – All The Results
Posted in: Consumer ReviewsAll the results of my USB power banks tests
Here are the results of testing 13 USB power banks (including two wild cards). I compare them across about 28 criteria, including real world capacity, voltage drops, energy density, price and fast charging capability.
Thanks to Franky for the USB Power monitor that was a huge value during testing: http://www.ebay.com/itm/USB-3-0-Power…
Link to the spreadsheet: http://mjlorton.com/forum/index.php?t…
Link to other review: http://thewirecutter.com/reviews/best…
1 Overall Rankings
2 Specs
3.1 USB Port Tests 1
USB Power Bank Number of USB Charge ports Rating of USB Charge Port 1 Rating of USB Charge Port 2 Input Charge Rating / Actual Charge rate Scud USA / Fremo P100 (10400 mAh @3.7v / 38.48 Wh) 1 5.1 V @ 2 A NA 5 V @ 2 A / 5 V @ 900 mA Anker (15 000 mAh) 2 5 v @ 2 A 5 V @ 1 A 5 V @ 1.5 A / 5 V @ 1.2 A - 1.6 A EasyAcc Classic (10 000 mAh / 37 Wh) 2 5 V @ 2.1 A 5 V @ 1.5 A 5 V @ 1.5 A / 5 V @ 1.1 A Maxboost Electron (10 000 mAh) 2 5 V @ 2.1 A 5 V @ 1 A 5 V @ 2.1 A / 5 V @ 890 mA Bolt Power (16500 mAh / 61.05 Wh) 1 5 V @ 2.1 A NA 12-15 V @ 1 A / 15 V @ 950 mA Goal Zero YETI150 (14 000 mAh / 150 Wh) 2 5 V @ 2.1 A 5 V @ 2.1 A 14 V - 29 V @ 5 A (60 W Max) / 13 V @ 3 A EasyAcc (15 600 mAh / 57.7 Wh) 2 5 V @ 1 A 5 V @ 2.1 A 5 V @ 2 A / 5 V @ 1.85 A Anker 2nd Gen Astro (10 000 mAh) 2 5 V @ 3A Total 5 V @ 3A Total 5 V @ 2 A / 5 V @ 2 A Anker 2nd Gen Astro Mini Lipstick (3 200m Ah / 11.84 Wh) 1 5 V @ 1 A NA 5 V @ 0.8 A / 5 V @ 0.8 A Intocircuit 2nd Gen Power Castle (13 000mAh / 48.1 Wh) 2 5 V @ 1 A 5 V @ 2.1 A 5 V @ 1.5 A / 5 V @ 1.5 A Poweradd Mini Portable (5000mAh) 1 5 V @ 2.1 A NA 5 V @ 1.5 A / 5 V @ 1.8 A Poweradd with Multi-Angle Portable Stand (10400mAh / 37 Wh) 2 5 V @ 1 A 5 V @ 2.4 A 5 V @ 1 A / 5 V @ 870 mA Smart Tech Apollon V8000 (8000 mAh) 1 5 V @ 2 A 12 V @ 0.8 A 5 V @ 2 A / 5 v @ 1.5 A 3.1 USB Port Tests 2
USB Power Bank Voltage at USB Charge Port - no load Voltage at USB Charge Port - 500 mA Voltage at USB Charge Port - 2 A (or quoted max if less than 2 A) Voltage at USB Charge Port - Max current Maxium Power output (Watts) (note, voltage level may be too low for some devices) Scud USA / Fremo P100 (10400 mAh @3.7v / 38.48 Wh) 5.03 4.99 4.9 V @ 2 A 4.75 V @ 2.6 A 12.35 Anker (15 000 mAh) 5.35 5.28 5.17 V @ 2 A 4.1 V @ 3.1 A 12.71 EasyAcc Classic (10 000 mAh / 37 Wh) 5.11 5.08 4.97 V @ 2 A 4.6 V @ 2.2 A 10.12 Maxboost Electron (10 000 mAh) 5.2 5.15 4.96 V @ 2 A 4.96 V @ 2.3 A 11.41 Bolt Power (16500 mAh / 61.05 Wh) 5.35 5.28 5.1 V @ 2 A 4.8 V @ 3 A 14.4 Goal Zero YETI150 (14 000 mAh / 150 Wh) 5.11 5.09 5.01 V @ 2 A 3.7 V @ 4.3 A 15.91 EasyAcc (15 600 mAh / 57.7 Wh) 5.21 5.23 5.05 V @ 2 A 5.06 V @ 2.2 A 11.13 Anker 2nd Gen Astro (10 000 mAh) 5.27 5.22 5.09 V @ 2 A 3.6 V @ 4.3 A 15.48 Anker 2nd Gen Astro Mini Lipstick (3 200m Ah / 11.84 Wh) 5.23 5.13 5.07 V @ 1 A 3.6 V @ 1.8 A 6.48 Intocircuit 2nd Gen Power Castle (13 000mAh / 48.1 Wh) 5.32 5.16 4.98 V @ 2 A 4.94 V @ 2.3 A 11.36 Poweradd Mini Portable (5000mAh) 5.12 5.09 4.9 V @ 2 A 4.9 V @ 2.1 A 10.29 Poweradd with Multi-Angle Portable Stand (10400mAh / 37 Wh) 5.19 5.06 4.9 V @ 2 A 4.7 V @ 2.7 A 12.69 Smart Tech Apollon V8000 (8000 mAh) 5.19 5.16 4.95 V @ 2 A 4.25 V @ 2.63 A 11.18 4 Fast Charge Tests
USB Power Bank Fast Charge compatibility - iPad Fast Charge compatibility - iPhone / iPod Fast Charge compatibility - Android Phone Fast Charge compatibility - BlackBerry Fast Charge compatibility - Android Tablet Scud USA / Fremo P100 (10400 mAh @3.7v / 38.48 Wh) No Yes Yes Yes Yes Anker (15 000 mAh) Yes - Port 1 Yes - Port 1 Yes - Port 1 Only Yes - Port 2 Yes - Port 1 EasyAcc Classic (10 000 mAh / 37 Wh) Yes - Port 1 Yes - Port 1 Yes - Port 1 Only Yes - Port 2 Yes Maxboost Electron (10 000 mAh) No Yes Yes Yes - Port 2 Yes - Port 2 Bolt Power (16500 mAh / 61.05 Wh) No Yes Yes No Charge! Yes Goal Zero YETI150 (14 000 mAh / 150 Wh) Yes Yes Yes Yes Yes EasyAcc (15 600 mAh / 57.7 Wh) Yes - Port 2 Yes - Port 2 Yes - Port 1 Only Yes Yes Anker 2nd Gen Astro (10 000 mAh) Yes @ 2.1 A! Yes Yes Yes Yes Anker 2nd Gen Astro Mini Lipstick (3 200m Ah / 11.84 Wh) No Yes Yes No No Intocircuit 2nd Gen Power Castle (13 000mAh / 48.1 Wh) Yes - Port 2 Yes Yes Yes Yes Poweradd Mini Portable (5000mAh) Yes Yes Yes Yes Yes Poweradd with Multi-Angle Portable Stand (10400mAh / 37 Wh) Yes - Port 2 Yes Yes Yes Yes - Port 1 Only Smart Tech Apollon V8000 (8000 mAh) No Yes Yes Yes Yes 5 Energy Density Comparisons
USB Power Bank Unit weight (grams / ounces) Energy Density (Wh / kg) Physical Size L x W x H (mm) Volume (L) Energy Volume (Wh / L) Scud USA / Fremo P100 (10400 mAh @3.7v / 38.48 Wh) 257 g / 9.0 oz 131.13 93 x 79 x 22 0.161 209.3 Anker (15 000 mAh) 318 g / 11.2 oz 134.09 125 x 77 x 24 0.231 184.59 EasyAcc Classic (10 000 mAh / 37 Wh) 238 g / 8.3 oz 157.94 133 x 72 x 17 0.1628 230.89 Maxboost Electron (10 000 mAh) 241 g / 8.5 oz 121 108 x 72 x 23 0.1788 163.09 Bolt Power (16500 mAh / 61.05 Wh) 590 g / 20.8 oz 68.98 185 x 85 x 45 0.7076 57.51 Goal Zero YETI150 (14 000 mAh / 150 Wh) 5545 g / 195.6 oz 25.51 197 x 165 x 147 4.778 29.61 EasyAcc (15 600 mAh / 57.7 Wh) 343 g / 12 oz 155.98 158 x 62 x 23 0.225 237.77 Anker 2nd Gen Astro (10 000 mAh) 221 g / 7.7 oz 151.177 137 x 67 x 17 0.156 214.17 Anker 2nd Gen Astro Mini Lipstick (3 200m Ah / 11.84 Wh) 83 g / 2.9 oz 118.92 95 x 23 (H x Diameter) 0.039 250.06 Intocircuit 2nd Gen Power Castle (13 000mAh / 48.1 Wh) 307 g / 10.8 oz 129.25 128 x 70 x 22 0.197 201.42 Poweradd Mini Portable (5000mAh) 151g / 5.3 oz 115.7 118 x 63 x 11 0.082 213.05 Poweradd with Multi-Angle Portable Stand (10400mAh / 37 Wh) 399 g / 14 oz 83.58 134 x 97 x 29 0.376 88.7 Smart Tech Apollon V8000 (8000 mAh) 196 g / 6.9 oz 143.42 129 x 69 x 17 0.151 186.16 6 Charge Times
USB Power Bank Time to full charge (Hours:Mins) Time to full charge per actual capacity Hour / 1 Ah Number of iPhone / iPod charges Scud USA / Fremo P100 (10400 mAh @3.7v / 38.48 Wh) 13:00 1.94 Hours / Ah 6.6 Anker (15 000 mAh) 10:00 1.23 Hours / Ah 8.3 EasyAcc Classic (10 000 mAh / 37 Wh) 09:00 1.25 Hours / Ah 7.4 Maxboost Electron (10 000 mAh) 14:00 2.48 Hours / Ah 5.7 Bolt Power (16500 mAh / 61.05 Wh) 05:30 0.71 Hours / Ah * External PSU 8 Goal Zero YETI150 (14 000 mAh / 150 Wh) 04:08 0.18 Hours / Ah * External PSU 22.7 EasyAcc (15 600 mAh / 57.7 Wh) 13:17 1.29 Hours / Ah 10.5 Anker 2nd Gen Astro (10 000 mAh) 06:40 1.05 Hours / Ah 6.55 Anker 2nd Gen Astro Mini Lipstick (3 200m Ah / 11.84 Wh) 05:20 2.76 Hours /Ah 1.94 Intocircuit 2nd Gen Power Castle (13 000mAh / 48.1 Wh) 09:15 1.2 Hours / Ah 7.78 Poweradd Mini Portable (5000mAh) 03:00 0.87 Hours / Ah 3.42 Poweradd with Multi-Angle Portable Stand (10400mAh / 37 Wh) 11:30 1.74 Hours / Ah 6.54 Smart Tech Apollon V8000 (8000 mAh) 04:20 0.79 Hours / Ah 5.51
