• UNI-T UT71D Multimeter review and buyers guide
    My review of the UNI-T UT71D multimeter
        UNI-T UT71D Multimeter review and buyers guide – Part 1
        1. The UNI-T UT71D multimeter Part 1
        In part 1 of this review I take a look at the features, functionality, resolution and accuracy of the UT71D. In some respects I compare it to the Agilent U1272A. I use both the PentaRef and DMMCheck Plus from Doug at VoltageStandard.com
        Review of the UNI-T UT71D multimeter / DMM – 4000 / 40000 count, 0.025% / 0.05% DC accuracy, internal data logging for 10 000 values, PC data logging.
        If there is enough interest in this multimeter Franky will stock it on his eBay store:
        http://www.99centHobbies.com
        Or contact Franky for discount on my forum.
        Further discussion and picture here on my forum: http://mjlorton.com/forum/index.php?t…
        Details and specs of the UNI-T (Unitrend) UT71D:
        http://www.uni-trend.com/UT71d.html
        Basic Functions Range Best Accuracy
        DC Voltage 400mV/4V/40V/400V/1000V (0.025%+5)
        AC Voltage 4V/40V/400V/1000V (0.4%+30)
        AC Bandwidth 100KHz
        DC Current 400µA/4000µA/40A/400mA/10A (0.08%+8)
        AC Current 400µA/4000µA/40A/400mA/10A (0.5%+15)
        Resistance 400W/4kW/40kW/400kW/4MW/40MW (0.3%+8)
        Capacitance 40nF/400nF/4µF/40µF/400µF/4mF/40mF (1%+20)
        Temperature (°C) -40°C ~ 1000°C (1%+30)
        Temperature (°F) -40°F ~ 1832°F (1.5%+50)
        Frequency 40Hz/400Hz/4kHz/40kHz/400kHz/4MHz/40MHz/­400MHz (0.01%+8)
        Duty Cycle 10%~90% (1%+30)
        4~20mA Loop 0~100% (1%+50)
        Power Measurement
        Special Functions
        Fused 10A Range
        Auto Ranging
        Current Measurement Alarm
        Function Set Up
        Auto Ranging
        Votage & Current : AC + DC Measurement
        Data Logging 9999
        Data Recall
        Diode
        Continuity Buzzer
        True RMS
        Peak Hold
        Max/Min Mode
        Relative Mode
        Data Hold
        USB
        Double Display Backlight
        Full Icon Display
        Sleep Mode
        Low Battery Display
        Input Impedance for DC Voltage Measurement
        DC 200mV : Around 2.5GW
        All Other Ranges : 10MW
        Max. Display 40000
        Analogue Bar Graph
        GENERAL CHARACTERISTICS
        Power 9V Battery (6F22)
        LCD Size 73 x 50 mm
        Product Colour Red and Grey
        Product Net Weight 384g
        Product Size 200 x 93 x 40mm
        Standard Accessories Test Lead, English Manual, Battery, Alligator Clip, USB Interface Cable,
        Software, Point Contact Temperature, Probe, Carrying Bag, Test Clip
        Standard Individual Packing Gift Box
        Standard Quantity Per Carton 20 pcs
        Standard Carton Measurement
        542 x 376 x 388mm
        (0.079 CBM Per Standard Carton)
        Standard Carton Gross Weight 18kg
        UNI-T UT71D Multimeter review and buyers guide – Part 2
        2. The UNI-T UT71D multimeter Part 2
        AC Bandwidth 100KHz
        Power Measurement
        Special Functions
        Fused 10A Range
        Auto Ranging
        Function Set Up
        Auto Ranging
        Data Logging 9999
        Data Recall
        Diode
        Continuity Buzzer
        True RMS
        Peak Hold
        Max/Min Mode
        Relative Mode
        Data Hold
        USB
        Full Icon Display
        Sleep Mode
        Low Battery Display
        Max. Display 40000
        Analogue Bar Graph
        LCD Size 73 x 50 mm
        542 x 376 x 388mm
  • Review of the UNI-T UT71D multimeter / DMM – 4000 / 40000 count, 0.025% / 0.05% DC accuracy, internal data logging for 10 000 values, PC data logging.
    AC Bandwidth 100KHz
    Power Measurement
    Special Functions
    Fused 10A Range
    Auto Ranging
    Function Set Up
    Auto Ranging
    Data Logging 9999
    Data Recall
    Diode
    Continuity Buzzer
    True RMS
    Peak Hold
    Max/Min Mode
    Relative Mode
    Data Hold
    USB
    Full Icon Display
    Sleep Mode
    Low Battery Display
    Max. Display 40000
    Analogue Bar Graph
    LCD Size 73 x 50 mm
    542 x 376 x 388mm
