Author Topic: Review: Fluke 17B, Chinese and New International version  (Read 14076 times)
« on: February 14, 2013, 01:49:06 AM »
The video review is here:https://www.youtube.com/watch?v=BDQBFe7GSGc
Some pictures...sorry...not the best...of the insides.
Re: Review: Fluke 17B, Chinese and New International version
« Reply #1 on: February 14, 2013, 05:10:19 AM »
The Fluke 17B is rumored to have the same CPU IC (FS9721_LP3) as the Uni-T 90C which is 4,000 count.
The datasheet for the chip indicates 3/sec update and low battery warning is 2.4V DC.
NevDickens
« Reply #2 on: February 15, 2013, 05:32:32 PM »
G'Day Martin,
Great video. I've purchased a chinese 17B recently, so it was good to see a comprehensive review on the unit. Interesting compared to the International version in which there didn't seem to be a lot of difference, if any only minor. It would be intersting to see a comparo between these units and other meters of around the same value.
cheers Neville
 ;D
He Who Laughs Last.................Didn't Get It :)
« Reply #3 on: February 17, 2013, 01:39:09 AM »
According to the FS9271_LP3 datasheet, it takes up to 15 seconds to measure a 100uF capacitor.  In your video it is not clear to me how long you waited.  I suspect if the Fluke 17B couldn't read a 100uF, it would have displayed 0L.
In fact when you tested the 100uF, you can see that when you disconnected the leads at 24:43 it displayed 91.2uF briefly.
« Reply #4 on: February 18, 2013, 03:50:32 AM »
G'Day Martin,
cheers Neville
 ;D
Hi Neville,
Thanks...have a just placed an order on another meter the will complete what I think will be an interesting comparison around this range and value.
I hope to do that video next week.
« Reply #5 on: February 18, 2013, 04:00:30 AM »
Aaaah....thanks for pointing that out...let me nip out and check that now....
Ok, you are correct...seemed like an age but it did eventually produce a reading of  98.2uF....what I did not like was that it displayed some other arbitrary readings prior to getting to the final reading which could be misleading.
I will repeat this on camera when I do the comparison.
Thanks.
wladimirjr
« Reply #6 on: November 04, 2013, 12:32:18 PM »
I have a question about CAT III?
In this link, http://www.fluke.com/fluke/m2en/digital-multimeters/Fluke-17B.htm?PID=75002
In "Features" the description is "CAT III 300 V". In "Specifications" the description is "CAT III measurements 600V".
The CAT III correct is 300V or 600V?
Thank you.
« Reply #7 on: November 05, 2013, 01:41:10 AM »
The user manual (page 12) for the 17B says CAT II 600V and CAT III 300V.
I believe the specifications tab has incorrect formatting.
wladimirjr
« Reply #8 on: November 05, 2013, 09:47:39 PM »
Thank you!!! ;)
