Author Topic: Cheap scope probes?  (Read 6389 times)
Cheap scope probes?
« on: May 30, 2013, 08:39:54 AM »
I have an old Hitachi V-222 20MHz oscilloscope. I use it with some dodgy coax cable which I made up with crocodile clips on the end.
I'd like some proper probes to use with it. I was wondering, am I likely to be OK with some cheap chinese ones, or did I ought to go for some better quality ones from a more well known brand?
I've never really used proper scope probes before, so I'm not too sure on what the quality is like.
Re: Cheap scope probes?
« Reply #1 on: May 30, 2013, 12:29:23 PM »
Use the cheap Chinese probes, and look out for a used set of Tek probes to compare with. With the 20MHz scope the cheep probes will work fne, just get a few sets so that you can toss them when they break. I use the cheap probes from RS, they work well enough for basic work. If you get some get plain X10 ones as well as switchable ones.
« Reply #2 on: June 02, 2013, 08:22:18 AM »
Thanks.
I'll have a look around ebay and dealextreme etc and get some cheap ones.
blankfield
« Reply #3 on: June 02, 2013, 09:45:41 AM »
I recommend this
I'm using it with DS1052e without any problems and build quality to price ratio is great.
From 0 to 1, from VEE to VCC.
